[Qgis-user] New user problems
Michael Treglia
mtreglia at gmail.com
Wed Dec 7 18:54:26 PST 2016
Also, for what it's worth, I developed the tutorial you're referencing (
http://mltconsecol.github.io/QGIS-Tutorial/). Note- it hasn't been
updated since version 2.12 (when I was last developing it for teaching
material) - thus, the operations should generally work as described, but
there may have been slight changes since 2.12.
If you notice anything that straight-up doesn't work the same or similar
with a newer version of QGIS, let me know directly (this e-mail address is
fine) or file it as a bug report in Github:
https://github.com/mltConsEcol/QGIS-Tutorial/issues
I have no immediate plans to update the tutorial, but will keep track of
these things and fix as I can/when I need to develop further for some
reason.
Cheers,
Mike
On Wed, Dec 7, 2016 at 7:31 PM, DelazJ <delazj at gmail.com> wrote:
> Hi,
> welcome to QGIS! Comments inline.
> 2016-12-08 0:56 GMT+01:00 G A Sansom <gasansom at npoint.net>:
>> OK. I am new to QGIS, but not so new to GIS in general.
>> Using 2.14.7 Essen and working through the QGIS-2.14-UserGuide-en.pdf
>> and a tutorial that I found on the web (Treglia_QGIS_Tutorial_2_12.pdf)
>> I have 3 problems (so far!)
>> 1) When setting Relations (in the Project Properties) and creating a
>> new
>> Relation with a name but nothing else, QGIS throws a dump (30+ meg)
>> and sometimes simply quits at that time.
>> Getting past this, so far I haven’t been able to see anything useful with
>> this feature.
> Maybe should you read http://docs.qgis.org/2.14/en/
> docs/user_manual/working_with_vector/attribute_table.html#
> creating-one-to-many-relations to see what the relations are designed for.
>> 2) Occasionally, when attempting to set symbology properties for a
>> Polygon shape file, QGIS starts treating the shape file like a LINE shape.
>> Even though it is a Polygon, only allowing line type symbology. It also
>> does NOT display anything of the data while doing this.
>> I am certain that it is a Polygon; for a while it did display the layer
>> and
>> allowed me to set a fill color.
>> Additionally, it allowed me to make a data column and fill it with $area,
>> which I assume that it would not allow if it was an unclosed line.
>> The only work-around that I can find is to remove the offending layer
>> and to bring it back into the project. If you have already placed in
>> into
>> the Print Composer, this is more than a little inconvenient.
> Weird! No idea
>> 3) Using the Print Composer, I built a map, then built an inset map to
>> show the big picture. When I attempted to export the composition, as
>> image, pdf or jpg it seems to refresh all of the maps on the page. This
>> makes it impossible to create the composition a single page production
>> map.
>> I have not found any work-around for this.
> You can fix the content of each map item by checking "Lock layers for map
> items" in its properties tab or creating a layer preset.
> See http://docs.qgis.org/2.14/en/docs/user_manual/print_
> composer/composer_items/composer_map.html#main-properties
> HTH,
> Harrissou
>> This last item, with no work-around, is a show stopper.
>> Alan
>> [image: Avast logo]
>> <https://www.avast.com/sig-email?utm_medium=email&utm_source=link&utm_campaign=sig-email&utm_content=emailclient>
>> This email has been checked for viruses by Avast antivirus software.
>> www.avast.com
>> Qgis-user mailing list
>> List info: http://lists.osgeo.org/mailman/listinfo/qgis-user
>> Unsubscribe: http://lists.osgeo.org/mailman/listinfo/qgis-user
URL: <http://lists.osgeo.org/pipermail/qgis-user/attachments/20161207/f92f49b0/attachment.html>
