[Qgis-user] Arc Map Packages
Kurt Menke
kurt at birdseyeviewgis.com
Fri Dec 9 14:08:47 PST 2016
Hi Grant,
If you unzip them yes. Map packages are compressed files containing the map
documents (mxd) and source data. The source data is usually in shapefile or
file geodatabase format along with standard raster formats like geotiffs. If
you unzip the mpk you can work with the files in QGIS. The spatial data will
be found in the commondata folder.
Kurt
Kurt Menke, GISP
Bird's Eye View
<http://www.birdseyeviewgis.com/> www.BirdsEyeViewGIS.com
Work: 505-265-0243
Cell: 505-362-1776
URL: <http://lists.osgeo.org/pipermail/qgis-user/attachments/20161209/dd6bf88f/attachment.html>
