[Qgis-user] New Projection Definition
Grant Boxer boxerg at iinet.net.au
Thu Dec 22 15:06:31 PST 2016
I am trying to import a raster image of the North American geology
(https://ngmdb.usgs.gov/gmna/) and the projection is defined as Modified
spherical transverse Mercator with a central meridian of 100 deg W and a
scale factor of 0.926.
My attempt is here "+proj=tmerc +lat_0=0 +lon_0=-100 +k=0.9260000000000001
+x_0=0 +y_0=0 +a=6371204 +b=6371204 +units=m +no_defs" but this does not
work.
The shp files associated with the image have prj files as follows
PROJCS["User_Defined_Transverse_Mercator",
GEOGCS["GCS_User_Defined",DATUM["D_User_Defined",
SPHEROID["User_Defined_Spheroid",6371204.0,0.0]],
PRIMEM["Greenwich",0.0],
UNIT["Degree",0.0174532925199433]],
PROJECTION["Transverse_Mercator"],
PARAMETER["False_Easting",0.0],
PARAMETER["False_Northing",0.0],
PARAMETER["Central_Meridian",-100.0],
PARAMETER["Scale_Factor",0.926],
PARAMETER["Latitude_Of_Origin",0.0],
UNIT["Meter",1.0]]
Can anyone suggest changes to my projection file that I would need for this?
Grant Boxer
Perth, Western Australia
URL: <http://lists.osgeo.org/pipermail/qgis-user/attachments/20161223/752948ee/attachment.html>
