[Qgis-user] Adding Points by Coordinates
Brent Wood
pcreso at yahoo.com
Sun Feb 7 18:04:40 PST 2016
Hi Grant,
You can add a text file (delimited text layer) of points pretty easily (the comma icon or from the layer menu).
Then just edit the text file with your favourite text editor. I suggest you create the file first, then open it in QGIS. Specify the field delimiter, if the first line has column names (usually a good idea), the CRS, which columns to use for X & Y coords and tick the "watch file" box to refresh when new lines are added.
No real need to build such a tool into QGIS when this works so well.
Cheers,
Brent Wood
To: qgis-user at lists.osgeo.org
Sent: Monday, February 8, 2016 2:39 PM
Subject: [Qgis-user] Adding Points by Coordinates
<!--#yiv2644109402 _filtered #yiv2644109402 {font-family:"Cambria Math";panose-1:2 4 5 3 5 4 6 3 2 4;} _filtered #yiv2644109402 {font-family:Calibri;panose-1:2 15 5 2 2 2 4 3 2 4;}#yiv2644109402 #yiv2644109402 p.yiv2644109402MsoNormal, #yiv2644109402 li.yiv2644109402MsoNormal, #yiv2644109402 div.yiv2644109402MsoNormal {margin:0cm;margin-bottom:.0001pt;font-size:11.0pt;font-family:"Calibri", "sans-serif";}#yiv2644109402 a:link, #yiv2644109402 span.yiv2644109402MsoHyperlink {color:blue;text-decoration:underline;}#yiv2644109402 a:visited, #yiv2644109402 span.yiv2644109402MsoHyperlinkFollowed {color:purple;text-decoration:underline;}#yiv2644109402 span.yiv2644109402EmailStyle17 {font-family:"Calibri", "sans-serif";color:windowtext;}#yiv2644109402 .yiv2644109402MsoChpDefault {} _filtered #yiv2644109402 {margin:72.0pt 72.0pt 72.0pt 72.0pt;}#yiv2644109402 div.yiv2644109402WordSection1 {}-->Is there an option in QGIS to add a point by entering its co-ordinates. For example I have a drill hole position in UTM coordinates and I want to create a new layer for this drill hole. Thanks Grant Grant BoxerConsultant Geologist (FAIG R.P. Geo)Perth, Western Australia
Qgis-user mailing list
Qgis-user at lists.osgeo.org
List info: http://lists.osgeo.org/mailman/listinfo/qgis-user
Unsubscribe: http://lists.osgeo.org/mailman/listinfo/qgis-user
URL: <http://lists.osgeo.org/pipermail/qgis-user/attachments/20160208/e5357620/attachment.html>
