[Qgis-user] custom string formatting for grid coordinate labels
Uwe Fischer
gisfisch at t-online.de
Tue Feb 16 07:07:08 PST 2016
Hello List, hello Nyall,
I have a question concerning the grid coordinate labels for map frames in
print composer. If you set the label format to "custom", you get to
"Expression based annotation" box where you can build expressions for
formatting, e.g. concat(left(@grid_number,3) , '<sup>E'). That works fine
in the editor and the footnote preview shows exactly the desired result (E
as an above positioned little index). But, in the map composer canvas, the
format string is rendered as text, that means <sup>E shows up as a text
string there.
Is there a way to apply the format rule (which seems to work) correctly to
the map composer?
Regards and thanks a lot,
Uwe
URL: <http://lists.osgeo.org/pipermail/qgis-user/attachments/20160216/0aa2beb5/attachment.html>
