[Qgis-user] Help with polygon
Nicolas Cadieux nicolas.cadieux at archeotec.ca
Tue Feb 16 07:55:42 PST 2016
If you don't have it,  I would download the SRTMGL1
(https://lpdaac.usgs.gov/dataset_discovery/measures/measures_products_table/srtmgl1_v003)
for the region.  I would use the raster math to Identify pixels lower
than the plateau.  Then, you could do a raster to vector conversion.
The other option (probably easier) is to do contour lines from the
SRTMGL1 (raster/extraction/contour line).  Then you could select the
contours and work with that.
Good Luck
Nicolas
Le 2016-02-16 10:44, Mariana Buzzi-2 [via OSGeo.org] a écrit :
> t of landscape, the plateau
View this message in context: http://osgeo-org.1560.x6.nabble.com/Help-with-polygon-tp5250866p5250871.html
Sent from the Quantum GIS - User mailing list archive at Nabble.com.
URL: <http://lists.osgeo.org/pipermail/qgis-user/attachments/20160216/173967ba/attachment.html>
