[Qgis-user] information
Brent Wood pcreso at yahoo.com
Fri Feb 19 12:06:34 PST 2016
Hi Gill,
QGIS needs to know exactly what CRS the data is before it can convert them to something else. The EPSG code is normally how you do this. If you see:http://spatialreference.org/ref/?search=irishthere seem to be 6 possibilities. I'm not sure what the difference is, but you should identify the correct EPSG code for your coordinates.
You can then (in QGIS with the dataset opened as a map - have you got that far?) right click on the layer in the layer tab to bring up the layer menu, & use the "Set layer CRS" facility to tell QGIS this (if it does not already know - in some cases it may have read this from the data automatically).
There are now 3 ways to "translate a long list of Irish grid references to a map which has lat and long data" depending on exactly what you mean.
You can then go to Project->Properties to set the QGIS map to EPSG:4326, which is basic lat/long coordinates. This will tell QGIS to display your Irish grid data as lat/long - ie: reproject on the fly to provide you with a lat/long map.
You can use the layer menu to save your layer, in a different format and/or projection as you specify. If you change the output CRS to EPSG:4326 & save it, the new dataset will be have lat/long coordinates. This creates a new data file (rather than a map), as a lat/long version of your data.
In the Print composer, for setting up a map layout for printing, you can have a map in (say) Irish grid coordinates, but set up labelled ticks on the map frame which are in lat/long. You can also choose to use decimal degrees, degrees with decimal minutes, optional NSEW suffixes, etc. This gives you a locally projected map labelled with degrees.
I hope this helps,
Cheers
Brent Wood
 To: "qgis-user at lists.osgeo.org" <qgis-user at lists.osgeo.org>
 Sent: Friday, February 19, 2016 11:51 PM
 Subject: [Qgis-user] information
<!--#yiv1273304796 .yiv1273304796hmmessage P{margin:0px;padding:0px;}#yiv1273304796 body.yiv1273304796hmmessage{font-size:12pt;font-family:Calibri;}-->HelloI am new to qgis and wondering how I translate a long list of Irish grid references to a map which has lat and long data?
Any pointing in the right direction would be appreciated.Gill
Qgis-user mailing list
Qgis-user at lists.osgeo.org
List info: http://lists.osgeo.org/mailman/listinfo/qgis-user
Unsubscribe: http://lists.osgeo.org/mailman/listinfo/qgis-user
URL: <http://lists.osgeo.org/pipermail/qgis-user/attachments/20160219/bca87455/attachment.html>
