[Qgis-user] QGIS 2.14: SpatiaLite 4.3, Geos 3.5, GDAL 2?
Jürgen E. Fischer
jef at norbit.de
Fri Feb 26 06:15:28 PST 2016
Hi Claas,
On Fri, 26. Feb 2016 at 12:35:36 +0100, Claas Leiner wrote:
> Does anyone know if there any hope that QGIS 2.14 is compiled for
> Ubuntu 14.04 with SpatiaLite 4.3.0 and Geos 3.5?
> Also because of the bugs # 13934. Furthermore digitizing SpatiaLite
> layers leads to the described crashes.
> The installation of Geos 3.5 and 4.3 SpatiaLite has not helped.
> Also GDAL 2 for Ubuntu 14.04?
Our builds are made against what Ubuntu 14.04 offers (ie. spatialite 4.1, GEOS
3.4, GDAL 1.10). There are also builds with ubuntugis dependencies, which
offers GDAL 1.11 - but apparently no newer versions of spatialite and geos.
If you've build newer versions of GEOS and SpatiaLite from source you should do
that for QGIS (see INSTALL[0]), otherwise it probably will still use the old
ones.
Jürgen
[0] https://htmlpreview.github.io/?https://raw.github.com/qgis/QGIS/master/doc/INSTALL.html
Jürgen E. Fischer norBIT GmbH Tel. +49-4931-918175-31
Dipl.-Inf. (FH) Rheinstraße 13 Fax. +49-4931-918175-50
Software Engineer D-26506 Norden http://www.norbit.de
QGIS release manager (PSC) Germany IRC: jef on FreeNode
Desc: Digital signature
URL: <http://lists.osgeo.org/pipermail/qgis-user/attachments/20160226/e42d421c/attachment.sig>
