[Qgis-user] layer variable not working in modeler
Nyall Dawson nyall.dawson at gmail.com
Sat Feb 27 18:07:50 PST 2016
On 28 February 2016 at 05:54, Kurt Menke <kurt at birdseyeviewgis.com> wrote:
> Hello everyone,
> I am trying to develop a model in QGIS 2.13.0-Master, that will add an
> attribute column populated with the layer name. I can do this in the
> standard Field Calculator using the @layer_name Layer variable.
> However, when I try repeating this in a model using the Field calculator
> algorithm, it produces NULL output. I’m guessing this is syntax issue,
> rather than a scoping issue, because creating a project level variable still
> I have been putting the variable in the Formula line of the Field calculator
> tool. For example: @layer_name
> Should variables work in the Processing modeler? If so am I just using
> incorrect syntax?
Damn... sorry... I didn't even realise there was a field calculator in
processing. This is fixed in master now, I'll get it backported for
2.14.1
Nyall
> Thanks!
> Kurt
> Kurt Menke, GISP
> Bird’s Eye View
> www.BirdsEyeViewGIS.com
> Work: 505-265-0243
> Cell: 505-362-1776
> Qgis-user mailing list
> List info: http://lists.osgeo.org/mailman/listinfo/qgis-user
> Unsubscribe: http://lists.osgeo.org/mailman/listinfo/qgis-user
