[Qgis-user] Import lines from cvs
Joris Hintjens
jorishin at gmail.com
Thu Jan 7 12:46:15 PST 2016
Thanks Nicolas,
But…
Trying to avoid python, as I am illiterate in that field (for now)
For the plugins P2one etc, in order to use that, I need separate lines for “From” and “To” points, but I can create them. That will be my next guess, after trying the other proposed solutions.
> Op 6 jan. 2016, om 21:25 heeft Nicolas Cadieux <nicolas.cadieux at archeotec.ca> het volgende geschreven:
> Hi,
> I think you will need to use the python console to do the job. I have no direct experience but if you look in the pyqgis developer cookbook and look for "Geometry Construction" you will find a reference to "gLine".
> With that, you can create a line with two or more points.
> Before doing that, look at the plugin (activate experimental plugin and Search for " line". There seems to be po plugins that can do it like PointConnector or Points2One...
> Good luck.
> Nicolas Cadieux M.Sc.
> Les Entreprises Archéotec inc.
> 8548, rue Saint-Denis Montréal H2P 2H2
> Téléphone: 514.381.5112 Fax: 514.381.4995
> www.archeotec.ca
> On Jan 6, 2016 2:58 PM, "Joris Hintjens [via OSGeo.org] " <[hidden email] <x-msg://4/user/SendEmail.jtp?type=node&node=5244012&i=0>> wrote:
> Hello,
> I’m lost.
> I have a list of movements. A table with (among others) a column “FROM” and a column “TO” (both containing coordinates)
> How can I import this in QGIS so that I have a bunch of lines going from FROM to TO?
> thanks for your comments
> Joris
> Qgis-user mailing list
> <a href="/user/SendEmail.jtp?type=node&node=5244005&i=0">[hidden email]
> List info: http://lists.osgeo.org/mailman/listinfo/qgis-user <http://lists.osgeo.org/mailman/listinfo/qgis-user>
> Unsubscribe: http://lists.osgeo.org/mailman/listinfo/qgis-user <http://lists.osgeo.org/mailman/listinfo/qgis-user>
> If you reply to this email, your message will be added to the discussion below:
> http://osgeo-org.1560.x6.nabble.com/Import-lines-from-cvs-tp5244005.html <http://osgeo-org.1560.x6.nabble.com/Import-lines-from-cvs-tp5244005.html>
> To start a new topic under Quantum GIS - User, email ml-node+s1560n4125267h38 at n6.nabble.com
> To unsubscribe from Quantum GIS - User, <a href="http://osgeo-org.1560.x6.nabble.com/template/NamlServlet.jtp?macro=unsubscribe_by_code&node=4125267&code=bmljb2xhcy5jYWRpZXV4QGFyY2hlb3RlYy5jYXw0MTI1MjY3fDYzNDQ4MjQxNg==">click here.
> <a href="http://osgeo-org.1560.x6.nabble.com/template/NamlServlet.jtp?macro=macro_viewer&id=instant_html%21nabble%3Aemail.naml&base=nabble.naml.namespaces.BasicNamespace-nabble.view.web.template.NabbleNamespace-nabble.view.web.template.NodeNamespace&breadcrumbs=notify_subscribers%21nabble%3Aemail.naml-instant_emails%21nabble%3Aemail.naml-send_instant_email%21nabble%3Aemail.naml" style="font:9px serif">NAML
> View this message in context: Re: Import lines from cvs <http://osgeo-org.1560.x6.nabble.com/Import-lines-from-cvs-tp5244005p5244012.html>
> Sent from the Quantum GIS - User mailing list archive <http://osgeo-org.1560.x6.nabble.com/Quantum-GIS-User-f4125267.html> at Nabble.com.
URL: <http://lists.osgeo.org/pipermail/qgis-user/attachments/20160107/536ed1ca/attachment.html>
