[Qgis-user] Data plotting problem, bug?
Patty Rehn
quicksilversystems at gmail.com
Mon Jan 11 15:38:58 PST 2016
For QGIS 2.10.1 Pisa, Win8
I am attempting to plot some data (about 50 points, imported csv, converted
to shape file);
as graduated by size, divided by natural breaks, 8 classes, link class
boundaries, simple circle markers
The problem is one point will not plot, unless the class is only that point
(class 1):
1 .449872-.449872
2 .449872-.649973
3 .648873-.749909
etc
The point should plot with class 2 but does not.
If I delete class 1, the point goes away.
I have tried tweaking the class values such that the value should be
included in
class 2 also, but no difference.
The circles are sized with the lowest values as the largest circles, if
that matters.
I have another similar layer from another portion of the same data, treated
similarly,
that seems to plot no problem.
Additionally, sometimes the “show feature count” function gives the
correct number of feature in the class but other times, it only lists zeros.
Thank you for your suggestions.
Patty
URL: <http://lists.osgeo.org/pipermail/qgis-user/attachments/20160111/aaa5a543/attachment.html>
