[Qgis-user] Smoothing elevation data?
Nicolas Cadieux
nicolas.cadieux at archeotec.ca
Tue Jan 12 07:33:55 PST 2016
Use Single band pseudocolor, Mode: Continuous or boost the number of
Classes to 255, and play with the min max values. You should be able to
create a color ramp with more intermediate values. I imagine you do
have more then 4 or 5 different elevations values in the DEM? If not,
you could always filter your data using the SAGA simple filter found in
the processing module. Than will change the data values so keep a copy
of the original data.
I a good result, place your hillshade under this dem raster and change
the blending mode to multiply.
Cheers
Nicolas
Le 2016-01-12 09:39, Sebastian Stüwe [via OSGeo.org] a écrit :
> Dear group,
> another question: I am using a discrete color ramp on a topographic
> file, but I would like it to be smoother. Is there an algorithm you
> could apply to make it look better? See zoomed in example attached.
> Thank you!
> Sebastian.
> Lutheran Church in Liberia
> Sebastian Stüwe, MEd
> Consultant LCLSS
> Deputy Director CED
> P.O. Box 10-1046
> 13th street/Sinkor
> Monrovia
> Liberia
> +231 775 127409
> +49 176 63672480
> Qgis-user mailing list
> [hidden email] </user/SendEmail.jtp?type=node&node=5244741&i=0>
> List info: http://lists.osgeo.org/mailman/listinfo/qgis-user
> Unsubscribe: http://lists.osgeo.org/mailman/listinfo/qgis-user
> *signature.asc* (859 bytes) Download Attachment
> <http://osgeo-org.1560.x6.nabble.com/attachment/5244741/1/signature.asc>
> If you reply to this email, your message will be added to the
> discussion below:
> http://osgeo-org.1560.x6.nabble.com/Smoothing-elevation-data-tp5244741.html
> To start a new topic under Quantum GIS - User, email
> ml-node+s1560n4125267h38 at n6.nabble.com
> To unsubscribe from Quantum GIS - User, click here
> <http://osgeo-org.1560.x6.nabble.com/template/NamlServlet.jtp?macro=unsubscribe_by_code&node=4125267&code=bmljb2xhcy5jYWRpZXV4QGFyY2hlb3RlYy5jYXw0MTI1MjY3fDYzNDQ4MjQxNg==>.
> NAML
> <http://osgeo-org.1560.x6.nabble.com/template/NamlServlet.jtp?macro=macro_viewer&id=instant_html%21nabble%3Aemail.naml&base=nabble.naml.namespaces.BasicNamespace-nabble.view.web.template.NabbleNamespace-nabble.view.web.template.NodeNamespace&breadcrumbs=notify_subscribers%21nabble%3Aemail.naml-instant_emails%21nabble%3Aemail.naml-send_instant_email%21nabble%3Aemail.naml>
View this message in context: http://osgeo-org.1560.x6.nabble.com/Smoothing-elevation-data-tp5244741p5244764.html
Sent from the Quantum GIS - User mailing list archive at Nabble.com.
URL: <http://lists.osgeo.org/pipermail/qgis-user/attachments/20160112/6aedb467/attachment.html>
