[Qgis-user] Windows bluescreen with QGIS?
Michael Schulz
mandschulz at googlemail.com
Mon Jan 18 12:27:08 PST 2016
Hey Matthias and Nathan,
thanks for your ideas. I'll look into these and try to create a more
detailed error description.
Cheers, Michael
Am 18.01.2016 13:19 schrieb "Nathan Woodrow" <madmanwoo at gmail.com>:
> Also note that blue screens are normally caused by bad drivers, so also
> check recent installed drivers, printers, scanners, etc.
> - Nathan
> On Mon, Jan 18, 2016 at 10:09 PM, Matthias Kuhn <matthias at opengis.ch>
> wrote:
>> Hi Michael,
>> This sounds severe, but from the information provided so far it is very
>> hard to tell what could possibly be the cause for this.
>> You could try a couple of things:
>> * Check the memory usage while it happens [1]
>> * Disable all plugins, delete the local qgis configuration folder
>> * Provide information about the projects which cause the issue (is there
>> a special data provider, extremely big dataset, special styling...
>> involved).
>> * Update your Windows with all the latest patches and updates (you will
>> probably have to ask your local IT service if they have done / will do that
>> for you)
>> Best regards,
>> Matthias
>> [1]
>> http://windows.microsoft.com/en-us/windows7/view-how-much-memory-your-computer-is-using
>> On 01/18/2016 12:52 PM, Michael Schulz wrote:
>> Dear users,
>> I keep having an issue since one week, that when using QGIS 2.12(.2) /
>> 2.10 with some projects, my PC crashes with a windows blue screen (Win7 64
>> Pro). Sometimes a bad_pool_header or system_service_exception error. I'm
>> not saying this is caused by QGIS, but it is (more or less) reproducible
>> and doesn't happen when I'm not using QGIS.
>> I wonder if this could somehow be related to QGIS specifically, or if it
>> is a memory issues (hardware failure). Problem is that I'm in a company
>> network with quiet restricted access to my machine. I was wondering whether
>> someone could give me a hint or suggestions, where I could start looking
>> into this.
>> Thanks, Michael
>> Michael Schulz
>> Qgis-user mailing listQgis-user at lists.osgeo.org
>> List info: http://lists.osgeo.org/mailman/listinfo/qgis-user
>> Unsubscribe: http://lists.osgeo.org/mailman/listinfo/qgis-user
>> Matthias Kuhn
>> OPENGIS.ch - https://www.opengis.ch
>> Spatial • (Q)GIS • PostGIS • Open Source
URL: <http://lists.osgeo.org/pipermail/qgis-user/attachments/20160118/ac568d24/attachment.html>
