[Qgis-user] Categorized layer: match label colour to category colour?
Andreas Neumann a.neumann at carto.net
Thu Jan 21 12:50:49 PST 2016
Hi Bernd,
You can use variables to make updates easier - see the blog posts from
Nyall:
http://nyalldawson.net/2015/12/exploring-variables-in-qgis-pt-3-layer-level-variables/
You can store colors, threshold values and font-sizes or other stuff in
variables either globally, on the project or layer level. Then you can
use the variables wherever you want.
You need 2.12 for that.
Andreas
On 21.01.2016 19:35, Bernd Vogelgesang wrote:
> Hi folks,
> i digitized lines of bird species flying around in an area.
> The plan is to render the layer categorized by species and adjust the
> colours so you get the best distinction between the species and best
> contrast with the background.
> For further information, the lines need to have labels as well, cause
> we deal with 25 + x species, so there is no way to figure out on one
> glimpse which line colour is which species.
> Labeling with one colour adds more mess to the map, so my idea was
> just to set the label colour to the colour of the corresponding category.
> Being lazy, I wonder if there is some work flow to read out and add
> the line colour of a feature to the dataset, so I can just set the
> label colour to data driven and do not have to do that manually?
> Using QGIS 2.8.3 on Linux, but could also switch to 2.12 if necessary...
> Cheers
> Bernd
> Qgis-user mailing list
> List info: http://lists.osgeo.org/mailman/listinfo/qgis-user
> Unsubscribe: http://lists.osgeo.org/mailman/listinfo/qgis-user
