[Qgis-user] QGIS 2.12.3-1 crashes on startup - Arch Linux
Enock Seth Nyamador
kwadzo459 at gmail.com
Thu Jan 21 13:54:14 PST 2016
Thanks for your quick responses.
Richard,
- Arch Linux 64 Bits with kernel 4.3.3-3.
- Installed from AUR [1]
Matthias,
renamed but still not starting, just the splash screen as usual.
1. https://aur.archlinux.org/packages/qgis/
Best,
- Enock
UMaT, Tarkwa
enockseth.github.io
On Thu, Jan 21, 2016 at 9:35 PM, Matthias Kuhn <matthias at opengis.ch> wrote:
> Hi
> On 01/21/2016 10:33 PM, Richard Duivenvoorde wrote:
> > On 21-01-16 21:51, Enock Seth Nyamador wrote:
> >> Hi QGISers,
> >> Kindly help me out I've been trying to figure out what is prenventing my
> >> QGIS from working as it used. Lot of web searches couldn't help either.
> >> When I run it from terminal this is the error message I get:
> >> Warning: loading of qgis translation failed
> >> [/usr/share/qgis/i18n//qgis_en_US]
> >> Warning: loading of qt translation failed
> >> [/usr/share/qt4/translations/qt_en_US]
> >> Warning: QCss::Parser - Failed to load file "/style.qss"
> > Hi Enock,
> > those warnings are 'normal', and not errors which would prevent QGIS
> > from starting.
> > please give more information about your setup:
> > - which linux distro/version
> > - which repo's or how did you install/compile?
> And foremost, try to rename your $HOME/.qgis2 folder temporarily to
> something else to see if it's a plugin or configuration issue.
> Best
> > etc etc
> > Regards,
> > Qgis-user mailing list
> > Qgis-user at lists.osgeo.org
> > List info: http://lists.osgeo.org/mailman/listinfo/qgis-user
> > Unsubscribe: http://lists.osgeo.org/mailman/listinfo/qgis-user
> Matthias Kuhn
> OPENGIS.ch - https://www.opengis.ch
> Spatial • (Q)GIS • PostGIS • Open Source
URL: <http://lists.osgeo.org/pipermail/qgis-user/attachments/20160121/e3e0e096/attachment.html>
