[Qgis-user] OSGeo4W-packages for GRASS 7 only in QGIS
Blumentrath, Stefan
Stefan.Blumentrath at nina.no
Fri Jan 22 00:47:19 PST 2016
Thanks, I shall test the nightlies and report back!
Cheers
Stefan
-----Original Message-----
From: Qgis-user [mailto:qgis-user-bounces at lists.osgeo.org] On Behalf Of Jürgen E. Fischer
Sent: 22. januar 2016 09:23
To: qgis-user at lists.osgeo.org
Subject: Re: [Qgis-user] OSGeo4W-packages for GRASS 7 only in QGIS
Hi Stefan,
On Thu, 21. Jan 2016 at 22:33:37 +0000, Blumentrath, Stefan wrote:
> I just tried the 2.12.3 version with the GRASS7-plugin and GRASS
> 7.0.3RC1 (since the batch-file in the plugin is pointing to that
> version) in OSGeo4W 32bit. Unfortunately, GRASS 7 does not seem to be recognized in QGIS:
> mapsets only show up as folders and the plugin is not available...
> Any idea what might be the issue here?
Two issues.
Apparently GRASS meanwhile moved on to GRASS 7.0.3RC2 while 2.12.3 was built
against 7.0.3RC1. Not sure why the stable grass package is replaces with RCs
and whether it's necessary to embed the exact version number in the file names, but that way it's easy to break GRASS support in QGIS.
The second issue is that GRASS bin directory also needs to be added to the PATH (not sure since when). That's fixed in 244f83e and 23cdda2. Please verify with one of the next nightlies (qgis-dev or qgis-rel-dev).
Jürgen
Jürgen E. Fischer norBIT GmbH Tel. +49-4931-918175-31
Dipl.-Inf. (FH) Rheinstraße 13 Fax. +49-4931-918175-50
Software Engineer D-26506 Norden http://www.norbit.de
