[Qgis-user] OpenJPEG
Even Rouault even.rouault at spatialys.com
Mon Jan 25 08:39:52 PST 2016
Le lundi 25 janvier 2016 17:18:18, Aaron Boxer a écrit :
> Hello,
> I have made improvements to OpenJPEG speed and memory usage,
> and I am releasing the code under the Affero GPL license.
Aaron,
You're of course the ultimate voice for licensing choices of your code but
given that you've already submitted code as PR to the main OpenJPEG project,
peple could reasonably assume it was intended to be under the same BSD 2-
clause license.
Especially since https://github.com/CodecCentral/ronin mentions BSD-2 in the
main README and LICENSE files.
I find it not very respectful for people included myself who have, apparently
wrongly, tested or reviewed it under that assumption.
I don't think it will be mergable into mainline openjpeg if you keep it under
Affero GPL, but that's perhaps intended.
Others: this relates to discussions on gdal-dev (& openjpeg list/tracker).
Look for openjpeg in subjects at
https://lists.osgeo.org/pipermail/gdal-dev/2016-January/date.html
Even
http://www.spatialys.com
