[Qgis-user] QGIS Server sometimes not sending commits to postgis
Nathan Woodrow madmanwoo at gmail.com
Tue Jan 26 18:29:09 PST 2016
I'm not sure relying on the QGIS cache to hold your features for you while
you work offline is a great idea, and IMO is only going to give you pain in
the long run.  Better to download the features into something like sqlite
or shapefile using OGR and then create a sync type process to push back up
after the days work.
Just working on cached WFS features also leaves you with no data if QGIS
crashes or computer shuts down.
- Nathan
On Tue, Jan 26, 2016 at 11:29 PM, Alessandro Pasotti <apasotti at gmail.com>
wrote:
> 2016-01-26 13:37 GMT+01:00 jaitor <sigeo.agmartin at getxo.eus>:
>> Hi,
>> I am running a Windows Server 2012 server.
>> PostgreSQL 9.3.5, 64-bit
>> POSTGIS 2.1.3
>> QGIS Server 2.6.1-2
>> QGIS Desktop 2.8.3
>> I am using a Microsoft Surface Pro 4 tablet using QGIS Desktop 2.12 to
>> edit
>> some layers stored in the Postgresql database. The layers in the tablet
>> are
>> WFS layers served by QGIS Server.
>> When I toogle editing after inserting some data in the layer to force the
>> data to be sent and stored in the server sometimes the commit is not being
>> done from QGIS Server to the Database.
>> I can see that the POST http request arrives to the server ok, but
>> sometimes
>> I can't see a commit (update) in the database and some other times it
>> works
>> ok and does the commit.
>> I ensure every time that internet connection is fine.
>> When loading the QGIS project with 50 WFS layers in the tablet (client),
>> sometimes two or three layers are not read and I need to click in apply
>> several times until they are read properly and the project finishes
>> loading.. I don't know if this problem is related to the one I mentioned
>> before.
>> The problem that worries me is the first one, because there is people
>> working in field inserting data the whole day, and when they arrive to
>> their
>> office they connect teh tablet to wifi (or even ethernet cable) to ensure
>> internet is fine and they toogle edition to save changes. As mentioned
>> before, sometimes data is not stored in postgis but no error is propagated
>> to QGIS Client, so the user thinks that the data has been stores
>> correctly.
>> The funny thing is that they have been working for 40 days and hey only
>> got
>> this problem once, but since last week they have had this problem every
>> day...
>> I've been trying to activate QGIS Server logs to see what error it is
>> giving
>> adding these two lines to D:\OSGeo4W\httpd.d\httpd_qgis.conf
>> SetEnv QGIS_SERVER_LOG_FILE /var/tmp/qgislog.txt
>> SetEnv QGIS_SERVER_LOG_LEVEL 0
>> But no log file is being generated.
> If you are using FAST CGI, you can try:
> FcgidInitialEnv QGIS_DEBUG 1
> FcgidInitialEnv QGIS_SERVER_LOG_FILE /tmp/qgis-000.log
> FcgidInitialEnv QGIS_SERVER_LOG_LEVEL 0
> Hope this helps.
> Alessandro Pasotti
> w3:   www.itopen.it
> Qgis-user mailing list
> List info: http://lists.osgeo.org/mailman/listinfo/qgis-user
> Unsubscribe: http://lists.osgeo.org/mailman/listinfo/qgis-user
URL: <http://lists.osgeo.org/pipermail/qgis-user/attachments/20160127/ad841940/attachment.html>
