[Qgis-user] General interest in geological support for QGIS?
Fernando M. Roxo da Motta
petro at roxo.org
Sat Jan 30 11:11:16 PST 2016
On Sat, 30 Jan 2016 10:47:01 -0800, John Harrop <jcharrop at gmail.com>
wrote:
I have been playing with a set of processing scripts for seismic 3D
planning in QGIS. I am pretty sure that they are very inefficient and
cumbersome. I am working all the time with shapefiles, even knowing
that a small portable database (SQlite or Spatialite) would be much
better. The point is my complete incompetence to work with
databases. :(
My first think was to create a plug-in set for the task, but the
processing scripts had a shorter development cycle. (aka I am too
Lazy;))
> Since we have been talking about geological symbol fonts…
> What is the level of interest in other geological tools? I would
> very much like to see the momentum in QGIS carry on into building
> tools in QGIS and/or PostGIS to support drilling, geochemistry and
> geophysics field surveys.
> For example, I have run simple drill sections as “projections” with
> the data calculated in a spreadsheet. Recently I have been
> (enjoying!) processing magnetic surveys in R and building profiles
> for plotting in plan view along the survey lines. The tools are
> there to build a good exploration suite like those provided
> commercially for MapInfo and ESRI.
> Any other interest in this? Should we be more formalizing a project?
> John
> > On Jan 30, 2016, at 12:56 AM, gene <martin.laloux at gmail.com> wrote:
> > The solution we were using was a True Type font (Font marker
> > symbol) with geological symbols (as ArcGIS with the geology ttf
> > symbols). We cannot use directly this ESRI police ( FAQ: What are
> > the applicable copyright restrictions on Esri fonts?"
> > <http://support.esri.com/en/knowledgebase/techarticles/detail/32155
> > > ) but it is relatively easy to create a new True Type Font with
> > > geological symbols
> > with FontForge <https://fontforge.github.io/en-US/> . You draw
> > the symbols with a classical interface
> > <http://osgeo-org.1560.x6.nabble.com/file/n5248101/fontforge2.jpg>
> > and you generate the True Type Font (look at QGIS and fonts as
> > symbols, use and creation with FontForge
> > <http://www.portailsig.org/content/qgis-et-les-polices-de-caracteres-comme-symboles-utilisation-et-creation-avec-fontforge>
> > , in French but the figures are universal). You can even copy/paste
> > a SVG symbol as a new character of the font or export a character
> > to a SVG file . You can change the color and the size of a
> > character without problem and it is easy to distribute
> > View this message in context:
> > http://osgeo-org.1560.x6.nabble.com/Geological-Map-Symbols-Continued-tp5248087p5248101.html
> > Sent from the Quantum GIS - User mailing list archive at
> > Nabble.com. _______________________________________________
> > Qgis-user mailing list Qgis-user at lists.osgeo.org
> > List info: http://lists.osgeo.org/mailman/listinfo/qgis-user
> > Unsubscribe: http://lists.osgeo.org/mailman/listinfo/qgis-user
Roxo
---------------- Non luctari, ludare -------------------+ WYSIWYG
Fernando M. Roxo da Motta <petro at roxo.org> | Editor?
Except where explicitly stated I speak on my own behalf.| VI !!
( Usuário Linux registrado #39505 ) | I see text,
------------ Quis custodiet ipsos custodes?-------------+ I get text!
