[Qgis-user] QGIS Viewer
Blumentrath, Stefan Stefan.Blumentrath at nina.no
Fri Jul 1 00:11:32 PDT 2016
If you start QGIS with the --configpath option, you avoid hacking the registry, as all such settings are written into the folder the “--configpath” option points to (more precisely, into the QGIS.ini file)
That folder can be in the users Home directory and e.g. copied from a network drive...
See:
http://gis.stackexchange.com/questions/96094/how-to-start-qgis-with-configpath-option-on-windows
Cheers
Stefan
From: Qgis-user [mailto:qgis-user-bounces at lists.osgeo.org] On Behalf Of Tyler Veinot
Sent: 1. juli 2016 06:00
To: Heikki Vesanto <heikki.vesanto at gmail.com>; Eric Goddard <egoddard1010 at gmail.com>
Cc: qgis-user at lists.osgeo.org; tech at wildintellect.com
Subject: Re: [Qgis-user] QGIS Viewer
Well there seems to be plenty of options; I like the idea of disabling some of the interface options. I highly doubt too many of my coworkers know how to access the registry and those that do I am not worried about making edits.
Thanks all.
Cheers
Sent from my Bell Sony device over Canada’s largest network.
---- Eric Goddard wrote ----
If you're using the OSGeo4W installer, you could uninstall the filegdb
api so that QGIS has to use the OpenFileGDB driver (which is read
only) to view file geodatabases. The QGIS stand-alone installer just
has the OpenFileGDB driver, so nothing extra is required there.
Eric
On Thu, Jun 30, 2016 at 1:56 PM, Heikki Vesanto
<heikki.vesanto at gmail.com<mailto:heikki.vesanto at gmail.com>> wrote:
> If you remove customise from the menu they will have to edit their registry
> to get it back. So will stop all but the most determined user.
> On 30 Jun 2016 19:27, "Brent Wood" <pcreso at yahoo.com<mailto:pcreso at yahoo.com>> wrote:
>> And how do you stop a user from turning them on again?
>> Brent Wood
>> ________________________________
>> From: Heikki Vesanto <heikki.vesanto at gmail.com<mailto:heikki.vesanto at gmail.com>>
>> To: tech at wildintellect.com<mailto:tech at wildintellect.com>
>> Cc: qgis-user <qgis-user at lists.osgeo.org<mailto:qgis-user at lists.osgeo.org>>
>> Sent: Friday, July 1, 2016 6:18 AM
>> You can hide most of the interface using the settings>customise menu, no
>> plugin required.
>> On 30 Jun 2016 18:30, "Alex M" <tech_dev at wildintellect.com<mailto:tech_dev at wildintellect.com>> wrote:
>> On 06/30/2016 09:40 AM, James Keener wrote:
>> > How are users accessing the data?  If they're connecting to a
>> > database, can you simply not give them update permission?  If it's
>> > files, can you can keep read-only master copies on a public
>> > store/shared drive?
>> > Jim
>> > On Thu, Jun 30, 2016 at 12:20 PM, Tyler Veinot <tylerkveinot at gmail.com<mailto:tylerkveinot at gmail.com>>
>> > wrote:
>> >> Hi again;
>> >> Just wondering if there is a QGIS Viewer available, or any suggestions
>> >> as to
>> >> what I can use that is open source with some basic spatial search
>> >> capabilities and can view filegeodatabases?
>> >> I have been deploying QGIS to our staff to view our GIS Data and I am
>> >> starting to get a little nervous where someone could easily do some
>> >> awesome
>> >> geoprocessing damage to our data if they got to messing about. So does
>> >> QGIS
>> >> have something like Esri's Arc Explorer?
>> >> Thanks
>> >> Tyler
>> The other approach I've seen is to use a plugin to disable and hide most
>> of the interface.
>> Thanks,
>> Alex
>> Qgis-user mailing list
>> Qgis-user at lists.osgeo.org<mailto:Qgis-user at lists.osgeo.org>
>> List info: http://lists.osgeo.org/mailman/listinfo/qgis-user
>> Unsubscribe: http://lists.osgeo.org/mailman/listinfo/qgis-user
URL: <http://lists.osgeo.org/pipermail/qgis-user/attachments/20160701/be514462/attachment.html>
