[Qgis-user] Placement of attribute tables in print composer
Martin Stubbs martin at mstubbs.co.uk
Wed Jul 6 09:02:35 PDT 2016
Andreas,
Thank you for such a comprehensive reply. I will certainly look at the
work being done for QGIS 3.0 and see if I am able to support it.
Thanks
Martin
On 06/07/16 14:16, Neumann, Andreas wrote:
> Hi Martin,
> Unfortunately, what you want, is not possible currently. The only
> thing you can do is to place the dynamic elements (e.g. attribute
> table) last in your layout and let it flow over several pages. All the
> static stuff needs to be placed first.
> For QGIS 3.0, Nyall Dawson, will do a rewrite/redesign of the QGIS
> print composer. There will be an additional "reporting mode" to allow
> such things you want to do (page flow, place items relative to other
> items, etc.). See his website for more details:
> http://north-road.com/qgis-layout-and-reporting-engine-campaign/ - he
> will update it soon, after the release of QGIS 2.16. If you are
> interested in such functionality, and have some financial resources,
> we would very much welcome if you could join this crowd-funding
> effort, once, more information will be available. Caveat: you will
> have to wait until the 3.x releases, which will be in Feb/March 2017
> at the earliest (no gurarantees).
> Until then, your only chance to get something similar is to put
> everything in a dynamic HTML code and let it flow over multiple pages.
> QGIS 2.16 comes with an improvement to allow working with table
> relations. This change makes the current atlas feature (and
> additionally all attributes of related child features) available to
> the source of a composer HTML item, allowing the item to dynamically
> adjust its rendered HTML in response to the feature's properties. An
> example use case is dynamically populating a HTML table with all the
> attributes of related child features for the atlas feature. To use
> this, the HTML source must implement a "setFeature(feature)"
> JavaScript function. This function is called whenever the atlas
> feature changes, and is passed the atlas feature (and all related
> attributes) as a GeoJSON Feature.
> Sorry that I don't have better news - but at least the issue is known,
> devs are aware of it and will propose solutions for QGIS 3.0.
> Andreas
> On 2016-07-06 14:51, Martin Stubbs wrote:
>> Richard,
>> Thank you for your thoughts. Unfortunately the approach you suggest
>> would not allow the tables to move up or down the page as objects are
>> added or deleted from the maps in a dynamic way. I could add x and y
>> fields for each attribute table to my Atlas control layer but I would
>> need to update them every time new records were added. My document
>> has 50 pages of maps so I was hoping for a solution that would use
>> the position and size overides you describe but in a dynamic way.
>> Thanks
>> Martin
>> On 06/07/16 11:35, Richard McDonnell wrote:
>>> Martin,
>>> You can specify the position and size of the table?tables using
>>> attributes, you could set up an x and y column on your tables which
>>> you could use the *Data defined Overide* options to set your
>>> location this is under *Attribute Table, Item Options, Position and
>>> Size *on the composer.
>>> Might be a solution for you!
>>> Regards,
>>> Richard.
>>> On 05/07/2016 11:46, Martin Stubbs wrote:
>>>> Hi,
>>>> I am producing a multi page document using the atlas function in
>>>> print composer. I have pairs of pages with a map on the left side
>>>> and 4 attribute tables on the facing page showing details of 4
>>>> different objects on the map. For each pair of pages there are a
>>>> variable number of objects shown of each type. Each object is fetch
>>>> from its own postgis table as the fields stored for each object is
>>>> different.
>>>> At the moment I have the attribute tables defined to handle the
>>>> largest number of items found on the map but this means, on some
>>>> pages, there are large gaps before the next table starts. Would it
>>>> be possible to have a variable exported from an attribute table
>>>> that could be used to position the next table a suitable distance
>>>> apart?
>>>> Thanks for the help
>>>> Martin
>>>> _______________________________________________
>>>> Qgis-user mailing list
>>>> Qgis-user at lists.osgeo.org
>>>> List info: http://lists.osgeo.org/mailman/listinfo/qgis-user
>>>> Unsubscribe: http://lists.osgeo.org/mailman/listinfo/qgis-user
>>> *_Richard McDonnell_*
>>> *GIS Specialist PgD GIS AssocSCSI*
>>> *OPW FRM Data Management*
>>> *52 Stephens Green, Dublin 2.*
>>> TEL: 01 6476543
>>> OPW - Ag féachaint don am atá le teacht - Ag caomhnú ón am atá thart
>>> OPW - Looking to the future - Caring for the past
>>> <http://o8u0.mj.am/lnk/AEUAD8SfENwAAAAAAAAAAGWBseoAAP-HqY4AAAAAAATonABXfP7JI0IQtVyZSiuEv5rXOkfp3AAEtK4/3/ROASpnbsmcLf88BkUaXYCQ/aHR0cDovL3d3dy5vcHcuaWUv>
>>> Email Disclaimer: http://www.opw.ie/en/disclaimer/
>>> <http://o8u0.mj.am/lnk/AEUAD8SfENwAAAAAAAAAAGWBseoAAP-HqY4AAAAAAATonABXfP7JI0IQtVyZSiuEv5rXOkfp3AAEtK4/4/0A8iNnjgdavrRHI0BzRh4g/aHR0cDovL3d3dy5vcHcuaWUvZW4vZGlzY2xhaW1lci8>
>> Qgis-user at lists.osgeo.org <mailto:Qgis-user at lists.osgeo.org>
URL: <http://lists.osgeo.org/pipermail/qgis-user/attachments/20160706/2c59b919/attachment.html>
Name: not available
Type: image/gif
Desc: not available
URL: <http://lists.osgeo.org/pipermail/qgis-user/attachments/20160706/2c59b919/attachment.gif>
