[Qgis-user] Debian users: please confirm bug around SVG symbol previews
Neumann, Andreas a.neumann at carto.net
Thu Jul 7 06:44:33 PDT 2016
Hi Richard,
Thanks - it behaves exactly the same on Ubuntu.
I am inclined to close this bug http://hub.qgis.org/issues/14255 if
Paolo is the only one experiencing this issue. Seems like a local issue
with his directory structure.
Andreas
On 2016-07-07 15:37, Richard Duivenvoorde wrote:
> On 07-07-16 15:15, Neumann, Andreas wrote:
>> Hi Nelson,
>> Thanks for checking.
>> Are you sure the users home directory is added to the SVG paths by
>> default on Debian? I can't confirm this on Ubuntu.
>> I thought that by default this setting is empty.
> I'm on Debian Testing;
> I do not have a clean install available, but if I start qgis from
> commandline here with a fresh config:
> qgis --configpath /tmp/foo
> I end up with two items in the svg path:
> /home/richard/apps/qgis/master/debug/share/qgis/svg/
> /tmp/foo/svg/
> The first one is the svg directory of my installation (self compiled),
> the second is a svg directory in the configpath (which is your home dir
> by default I think?)
> Regards,
> Richard
> Qgis-user mailing list
> List info: http://lists.osgeo.org/mailman/listinfo/qgis-user
> Unsubscribe: http://lists.osgeo.org/mailman/listinfo/qgis-user
URL: <http://lists.osgeo.org/pipermail/qgis-user/attachments/20160707/5337e8b0/attachment.html>
