[Qgis-user] FW: Couldn't load QGIS utils
DelazJ delazj at gmail.com
Tue Jul 12 09:15:50 PDT 2016
Hi all,
Just wondering: wasn't it possible to remove silently any potential
Processing plugin (in most of the cases, it'll be under /.qgis2 folder)
during 2.16 installation?
Harrissou
2016-07-12 17:45 GMT+02:00 Matthias Kuhn <matthias at opengis.ch>:
> Hi Carlos,
> Processing has been part of core for a long time already.
> It has also been shipped as a separate plugin in parallel which caused a
> lot of troubles like you noticed now.
> This is no longer available and you are absolutely right in recommending
> removal if it has been installed from this sources.
> Matthias
> On 07/12/2016 04:49 PM, Carlos Cerdán wrote:
> > Thank you very much Matthias... I've just discovered it, and found that
> > Processing is now part of the core of QGIS, so if someone is updating
> > from 2.14 or less, must unistall the processing plugin to avoid
> > conflicts with Processing core (sorry if terms are not correct).
> > Now, all is fine... I hope.
> > Regards from Peru
> > Carlos
> > 2016-07-12 9:25 GMT-05:00 Matthias Kuhn <matthias at opengis.ch
> > <mailto:matthias at opengis.ch>>:
> >     Hi Carlos,
> >     As far as I know all functionality available in ftools is available
> in
> >     processing.
> >     There was a lot of duplicated code which was unmaintained so the
> >     decision was to put the full focus on one tool and avoid doing work
> >     twice.
> >     If there's anything missing, please report it!
> >     Regards
> >     Matthias
> >     On 07/12/2016 03:29 PM, Carlos Cerdán wrote:
> >     > There is an issue that can be related with this: ftools
> disappeared in
> >     > QGIS 2.16  (Ubuntu 16.04. Don't know about windows); so we still
> can't
> >     > do basic vectorial geoprocessing. I guess it's under revision.
> >     > Developers please light us...
> >     > 2016-07-12 6:33 GMT-05:00 Pim Verver <pim at travelingo.nl <mailto:
> pim at travelingo.nl>
> >     > <mailto:pim at travelingo.nl <mailto:pim at travelingo.nl>>>:
> >     >     Hi all,____
> >     >     __ __
> >     >     Yesterday I installed a 64 bits version of QGIS 2.16 and after
> >     >     startup  I got the following popup. After that QGis seems to be
> >     >     working okay (apart from the python disabling). Is there an
> obvious
> >     >     solution for this problem. I tried both the advanced and the
> express
> >     >     install, but no luck so far.____
> >     >     __ __
> >     >     Couldn't load QGIS utils.
> >     >     Python support will be disabled.____
> >     >     Traceback (most recent call last):
> >     >       File "", line 1, in
> >     >       File "C:/OSGEO4~1/apps/qgis/./python\qgis\utils.py", line
> 21, in
> >     >         standard_library.install_aliases()
> >     >       File
>  "C:\OSGEO4~1\apps\Python27\lib\site-packages\future\standard_library\__init__.py",
> >     >     line 483, in install_aliases
> >     >         import test
> >     >       File "C:\OSGEO4~1\bin\test.py", line 3, in
> >     >         for layer in iface.mapCanvas().layers():
> >     >     NameError: name 'iface' is not defined____
> >     >     Python version:
> >     >     2.7.5 (default, May 15 2013, 22:44:16) [MSC v.1500 64 bit
> (AMD64)]
> >     >     QGIS version:
> >     >     2.16.0-Nødebo 'Nødebo', d0b3e39
> >     >     Python path:
> >     >     ['C:/OSGEO4~1/apps/qgis/./python',
> u'C:/Users/Pim/.qgis2/python',
> >     >     u'C:/Users/Pim/.qgis2/python/plugins',
> >     >     'C:/OSGEO4~1/apps/qgis/./python/plugins',
> 'C:\\OSGEO4~1\\apps\\Python27\\lib\\site-packages\\matplotlib-1.3.1-py2.7-win-amd64.egg',
> 'C:\\OSGEO4~1\\apps\\Python27\\lib\\site-packages\\nose-1.3.3-py2.7.egg',
> 'C:\\OSGEO4~1\\apps\\Python27\\lib\\site-packages\\tornado-4.0.1-py2.7-win-amd64.egg',
> 'C:\\OSGEO4~1\\apps\\Python27\\lib\\site-packages\\backports.ssl_match_hostname-3.4.0.2-py2.7.egg',
> 'C:\\OSGEO4~1\\apps\\Python27\\lib\\site-packages\\certifi-14.05.14-py2.7.egg',
> 'c:\\osgeo4~1\\apps\\python27\\lib\\site-packages\\python_dateutil-2.1-py2.7.egg',
> >     >     'C:\\OSGEO4~1\\bin\\python27.zip',
> >     >     'C:\\OSGEO4~1\\apps\\Python27\\DLLs',
> >     >     'C:\\OSGEO4~1\\apps\\Python27\\lib',
> >     >     'C:\\OSGEO4~1\\apps\\Python27\\lib\\plat-win',
> >     >     'C:\\OSGEO4~1\\apps\\Python27\\lib\\lib-tk',
> 'C:\\OSGEO4~1\\bin',
> >     >     'C:\\OSGEO4~1\\apps\\Python27',
> >     >     'C:\\OSGEO4~1\\apps\\Python27\\lib\\site-packages',
> >     >     'C:\\OSGEO4~1\\apps\\Python27\\lib\\site-packages\\PIL',
> 'C:\\OSGEO4~1\\apps\\Python27\\lib\\site-packages\\jinja2-2.7.2-py2.7.egg',
> 'C:\\OSGEO4~1\\apps\\Python27\\lib\\site-packages\\markupsafe-0.23-py2.7-win-amd64.egg',
> 'C:\\OSGEO4~1\\apps\\Python27\\lib\\site-packages\\pytz-2012j-py2.7.egg',
> >     >     'C:\\OSGEO4~1\\apps\\Python27\\lib\\site-packages\\win32',
> >     >     'C:\\OSGEO4~1\\apps\\Python27\\lib\\site-packages\\win32\\lib',
> >     >     'C:\\OSGEO4~1\\apps\\Python27\\lib\\site-packages\\Pythonwin',
> 'C:\\OSGEO4~1\\apps\\Python27\\lib\\site-packages\\Shapely-1.2.18-py2.7-win-amd64.egg',
> 'C:\\OSGEO4~1\\apps\\Python27\\lib\\site-packages\\wx-2.8-msw-unicode',
> 'C:\\OSGEO4~1\\apps\\Python27\\lib\\site-packages\\xlrd-0.9.2-py2.7.egg',
> 'C:\\OSGEO4~1\\apps\\Python27\\lib\\site-packages\\xlwt-0.7.5-py2.7.egg']____
> >     >     __ __
> >     >     Kind regards,____
> >     >     __ __
> >     >     Pim Verver____
> >     >     __ __
> >     >     _______________________________________________
> >     >     Qgis-user mailing list
> >     >     Qgis-user at lists.osgeo.org <mailto:Qgis-user at lists.osgeo.org>
> >     <mailto:Qgis-user at lists.osgeo.org <mailto:Qgis-user at lists.osgeo.org
> >     >     List info: http://lists.osgeo.org/mailman/listinfo/qgis-user
> >     >     Unsubscribe: http://lists.osgeo.org/mailman/listinfo/qgis-user
URL: <http://lists.osgeo.org/pipermail/qgis-user/attachments/20160712/16e3e712/attachment.html>
