[Qgis-user] Contour symbology
Lester Anderson arctica1963 at gmail.com
Fri Jul 15 04:39:01 PDT 2016
That worked perfectly! Many thanks Andreas
On 15 July 2016 at 12:32, Neumann, Andreas <a.neumann at carto.net> wrote:
> Hi Lester,
> How about just adding
> AND Elev != 0
>  to the rule? Perhaps the first part should be in parenthesis ()
> Andreas
> On 2016-07-15 13:07, Lester Anderson wrote:
> Hello,
> I have a rule-based line symbology set up as below:
> "Elev" % 500 = 0 (thick lines - every 500m)
> "Elev" % 500 <> 0 (thin lines - all other lines)
> Is there a quick way to not draw the 0 contour as it is not the same
> level of detail as the coastline. Basically do all contours except 0.
> Thanks
> Lester
> Qgis-user mailing list
> List info: http://lists.osgeo.org/mailman/listinfo/qgis-user
> Unsubscribe: http://lists.osgeo.org/mailman/listinfo/qgis-user
