[Qgis-user] Backing up GIS Data
Bo Victor Thomsen
bo.victor.thomsen at gmail.com
Fri Jul 15 23:54:56 PDT 2016
I haven't any extensive experience with moving databases from windows to
linux or vice versa, but I've been moving (backup/restore) databases
between windows hundred of times.
* I'm normally using the "Custom/binary" format, because it's the
fastest method to do the backup/restore cycle.
* When I'm creating/ structuring a new spatial database, I always
leave the "public" schema alone and put data in another schema
created for that purpose.
* When doing a backup for the purpose of moving a database, I only
backup the aforementioned *data* schema, *not* the "public" schema,
thus avoiding taking backup of hundreds of PostGIS functions
residing in schema "public". This makes it easier to move spatial
data from one PostGIS-enabled database to another without annoying
errors.
* And - just as you - I use the "plain" format when it's necessary to
make some changes to the structure or fields with a text editor
during the move of the database.
Regards
Bo Victor Thomsen
AestasGIS
Denmark
Den 15/07/16 kl. 15:23 skrev Micha Silver:
> Hi
> ------ Original Message ------ Subject: Re: [Qgis-user] Backing up GIS
> Data Date: Fri, 15 Jul 2016 07:04:20 +0200 To: Qgis-user From: Bo
> Victor Thomsen
>> As an old GIS database dog -
>> * It's a wise and smart decision to use Postgres/PostGis for
>> storing and using spatial data.
>> * As for backup: Do *exactly* as Jeff writes :-). "Point in time"
>> backups are nice, but not the best backup solution for Postgres
>> databases. Jeff's solution is.
>> Regards
>> Bo Victor Thomsen
>> AestasGIS
>> Denmark
>> Den 14/07/16 kl. 21:26 skrev Jeff McKenna:
>>> Hi Tyler,
>>> This is a good question, and an important one, and don't feel bad
>>> about posting it here - likely we can all learn from this
>>> discussion, as it definitely involves the whole QGIS community.
>>> I have quite a lot of experience backing up databases, especially
>>> PostgreSQL/PostGIS databases. I can tell you that it is for sure
>>> important to run "pg_dump" as a daily backup (in addition to your
>>> whole server image/backup) - that pg_dump has saved me and my
>>> clients hundreds of times, and it is very portable and easy to
>>> access (as opposed to your whole image/machine backup). One very
>>> important point (that's I've learned from experience) when using
>>> pg_dump is to *always* use the custom binary/compressed output
>>> format (the "--format=c" commandline switch for pg_dump). I've had
> I have always used the default "plain" format for pg_dump backups.
> When time comes to migrate data to a new installation, it allows me to
> edit the SQL backup file: restore only some of the tables, change
> owners, schema names, even change the database name. This is just a
> minor convenience. Am I making a mistake? Should I move to the binary
> format to insure reliability?
> Thanks
>>> terrible times with the other output format types, especially when
>>> restoring a database from a Windows server to a Linux server etc
>>> (with hardcoded paths inside the backup). I live by that format,
>>> swear by it, from experience, moving so many client databases from
>>> one machine to another.
>>> Another mailing list to keep in mind is the PostGIS mailing list,
>>> where these backup topics also pop up from time to time - and
>>> discussions are more geo-related, so are very helpful, than just the
>>> generic PostgreSQL mailing list.
>>> So, definitely implement an additional backup process using pg_dump
>>> (you can experiment restoring it through the "pg_restore" command),
>>> you won't regret the effort spent.
>>> Happy QGIS-ing,
>>> -jeff
>> Qgis-user mailing list
>> List info:http://lists.osgeo.org/mailman/listinfo/qgis-user
>> Unsubscribe:http://lists.osgeo.org/mailman/listinfo/qgis-user
> Micha Silver
> Arava Drainage Authority
> +972-523-665918
URL: <http://lists.osgeo.org/pipermail/qgis-user/attachments/20160716/80b6b914/attachment.html>
