[Qgis-user] Interesting problem
Jeff McKenna jmckenna at gatewaygeomatics.com
Wed Jul 20 12:43:19 PDT 2016
Hi Tyler,
To test connections, I always first use the 'psql.exe' commandline
utility, and then once I verify that works I would try the 'ogrinfo.exe'
commandline utility.  Both should at least allow you to view the tables
in your database, or, display a readable error.
-jeff
Jeff McKenna
MapServer Consulting and Training Services
http://www.gatewaygeomatics.com/
On 2016-07-20 4:34 PM, Tyler Veinot wrote:
> I am trying to connect to one of my databases under a postgreSQL 9.5.3
> (x86) install on windows 7 and I can connect to my geoprocessing
> database, just a location where I use PostGIS function on spatial data,
> but I cannot connect to my workorders database. They are under the same
> install with the same connection parameters. I get a message "consult
> message log for details" when I test the connection but I cannot find
> the log with the details in it.
> Database; name; host, and port are correct so I don't know what the
> issue might be. I was connected to it through libre base but I have
> since closed that connection.
> Anyone have a similar issue?
> Tyler
