[Qgis-user] SAGA Module Fill Sinks XXL (Wang & Liu) not found in QGIS 2.12.3 Lyon
Andrew amcaninch at gmail.com
Wed Jun 1 13:41:33 PDT 2016
Ah, maybe you are using the simplified interface for processing?  I just
noticed that you don't see all of the sink tools in the simplified
interface.  Try switching to the advanced interface, at the bottom of the
processing panel.
Andrew
On Wed, Jun 1, 2016 at 1:38 PM, Andrew <amcaninch at gmail.com> wrote:
> Hi Alejandro,
> What platform are you using?  I don't think the problem is the SAGA
> version, I can run Fill Sinks XXL tools using the OSGE4W 64-bit version of
> SAGA, 2.1.2 with QGIS 2.8.9 and 2.14.3.
> andrew
> On Wed, Jun 1, 2016 at 5:25 AM, Alejandro Chamizo de Castro <
> alechamizo at gmail.com> wrote:
>> Hello colleagues,
>> I'm trying use Module Fill Sinks XXL (Wang & Liu) in QGIS 2.12.3 to do Water
>> control / drainage but I can find this module.
>> In my QGIS version I can see Fill Sinks, but not the other one and I see
>> that SAGA version is 2.1.2 and this module appears in 2.1.3 SAGA Version.
>> Can I update SAGA in QGIS?
>> Thanks a lot
>> [image: Logo]
>> Analista SIG
>> *+34 653681823* ยท info at agprecision.es
>> www.agprecision.es
>> [image: eco] No me imprimas si no es necesario. Protejamos el medio
>> ambiente
>> [image: View Tony Wilson's profile on LinkedIn]
>> <https://www.linkedin.com/profile/public-profile-settings?trk=prof-edit-edit-public_profile>
>>      <http://vizualize.me/alechamizo?r=alechamizo>
>> WEB: *http://www.gisland.es/ <http://www.gisland.es/>*
>> Enviado con MailTrack
>> <https://mailtrack.io/install?source=signature&lang=es&referral=alechamizo@gmail.com&idSignature=23>
>> Qgis-user mailing list
>> List info: http://lists.osgeo.org/mailman/listinfo/qgis-user
>> Unsubscribe: http://lists.osgeo.org/mailman/listinfo/qgis-user
URL: <http://lists.osgeo.org/pipermail/qgis-user/attachments/20160601/f68fa494/attachment.html>
