[Qgis-user] Antarctic polar stereographic graticules (composer)
Alex Mandel tech_dev at wildintellect.com
Thu Jun 2 07:26:57 PDT 2016
For smoother lines you can use my Lines Graticule (pyGraticule) maker in
in the Processing toolbox, scripts from online.
As for the 180, I had the same issue. I can't get any lines to show up
between 170 <-> -170, though my polygon renders correctly through that area.
This seems to be some sort of projection issue. Have you tried saving
the graticule to the polar projection and loading it. I recall in the
past projection on the fly doesn't always work right.
-Alex
On 06/01/2016 08:14 AM, Lester Anderson wrote:
> Hi Nicolas,
> The problem is not so much with the grid as that displays fine. The issue
> crops up with the map composer, and even with the grid as WGS-84 the same
> problem persists. Looked at both North and South polar views and the 180
> graticule is always missing irrespective of the increment used. The
> latitude lines do not change and are clear line segments; these should be
> smoother.
> Data that are in UTM and with WGS-84 graticules look fine (smooth latitude
> lines). Is there an issue with Polar views and graticules?
> Lester
> On 1 June 2016 at 11:41, Nicolas Cadieux <nicolas.cadieux at archeotec.ca>
> wrote:
>> Hi,
>> Try saving the layer in WGS-84. Then make sure the project is also in the
>> same projection.  It can help sometimes to make a spatial index.
>> Keep me posted.
>> Nicolas
>> On Jun 1, 2016 05:35, "Lester Anderson [via OSGeo.org] " <[hidden email]
>> <http:///user/SendEmail.jtp?type=node&node=5269320&i=0>> wrote:
>> Hello,
>> I had some Antarctic polar stereographic data and when applying a
>> WGS-84 long-lat grid in map composer it generated most of the
>> longitude lines (180 missing), and very crude latitude lines (clearly
>> visible straight line segments).
>> Is there any way to improve the latitude lines?
>> Lester
>> Tested in 2.10, 2.12, 2.14
>> Qgis-user mailing list
>> <a
>> href="/user/SendEmail.jtp?type=node&node=5269310&i=0">[hidden
>> email]
>> List info: http://lists.osgeo.org/mailman/listinfo/qgis-user
>> Unsubscribe: http://lists.osgeo.org/mailman/listinfo/qgis-user
>> *Ant2016.jpg* (38K) Download Attachment
>> <http://osgeo-org.1560.x6.nabble.com/attachment/5269310/0/Ant2016.jpg>
>> If you reply to this email, your message will be added to the discussion
>> below:
>> http://osgeo-org.1560.x6.nabble.com/Antarctic-polar-stereographic-graticules-composer-tp5269310.html
>> To start a new topic under Quantum GIS - User, email
>> ml-node+s1560n4125267h38 at n6.nabble.com
>> To unsubscribe from Quantum GIS - User, <a href="
>> http://osgeo-org.1560.x6.nabble.com/template/NamlServlet.jtp?macro=unsubscribe_by_code&node=4125267&code=bmljb2xhcy5jYWRpZXV4QGFyY2hlb3RlYy5jYXw0MTI1MjY3fDYzNDQ4MjQxNg==">click
>> here.
>> <a href="
>> http://osgeo-org.1560.x6.nabble.com/template/NamlServlet.jtp?macro=macro_viewer&id=instant_html%21nabble%3Aemail.naml&base=nabble.naml.namespaces.BasicNamespace-nabble.view.web.template.NabbleNamespace-nabble.view.web.template.NodeNamespace&breadcrumbs=notify_subscribers%21nabble%3Aemail.naml-instant_emails%21nabble%3Aemail.naml-send_instant_email%21nabble%3Aemail.naml
>> <http://osgeo-org.1560.x6.nabble.com/template/NamlServlet.jtp?macro=macro_viewer&id&%2361;instant_html%21nabble%3Aemail.naml&base&%2361;nabble.naml.namespaces.BasicNamespace-nabble.view.web.template.NabbleNamespace-nabble.view.web.template.NodeNamespace&breadcrumbs&%2361;notify_subscribers%21nabble%3Aemail.naml-instant_emails%21nabble%3Aemail.naml-send_instant_email%21nabble%3Aemail.naml>"
>> style="font:9px serif">NAML
>> View this message in context: Re: Antarctic polar stereographic
>> <http://osgeo-org.1560.x6.nabble.com/Antarctic-polar-stereographic-graticules-composer-tp5269310p5269320.html>
>> Sent from the Quantum GIS - User mailing list archive
>> <http://osgeo-org.1560.x6.nabble.com/Quantum-GIS-User-f4125267.html> at
>> Nabble.com.
