[Qgis-user] PostGIS to DXF
Richard McDonnell richard.mcdonnell at opw.ie
Thu Jun 9 09:17:56 PDT 2016
Thanks,
I had tried both initially, with little success, the initial data was
DGN, I used an ETL to extract the line and text geometry, the text
coming in as points.
I styled the text using the attributes extracted like text height and
rotation and all looks and works well within QGIS.
When I use the Export to DXF tool (option B), I get all the Linestrings
perfect, but I get styled points (based on the attributes) instead of Text.
I have added the extra column to one of the Tables, and will try the OGR
export (option A) tomorrow with that.
It is no big deal to add the column to the dataset, it can be added as
part of the ETL, If I get it all to work.
I can submit a bug report, but as for the sample data, It is a sensitive
dataset, so I cant send that.
It may also be the version of QGIS im using, not being the most up to
date 2.14.2-Essen
I will continue with it tomorrow, if I find a solution, I will post it.
Regards,
On 09/06/2016 17:03, Andreas Neumann wrote:
> Hi Richard,
> How did you export your DXF?
> There are two options:
> a) Save AS (through OGR)
> b) Menu Project --> Export DXF which is a native QGIS DXF export not
> using OGR.
> Option b) is much more powerful and should export your label fine -
> not with all details - as QGIS labels are more powerful than DXF
> labels, but basic stuff, such as font-family, font-size, multi-line
> labels, etc. should be exported fine.
> If not, please submit a bug report with some sample data.
> Option a) is what was discussed here, but is much more complicated -
> you would have to create separate columns with feature styles first.
> Andreas
> On 09.06.2016 17:08, Richard McDonnell wrote:
>> I am back again,
>> Using what you said as a guide, I added a column to the table using
>> the following
>> ALTER TABLE mv_lv_network_point
>> ADD COLUMN OGR_STYLE CHARACTER VARYING(80);
>> UPDATE mv_lv_network_point
>> SET OGR_STYLE =
>> 'LABEL(f:"Arial",s:{igds_text_size},a:{igds_rotation},t:{igds_text_string})'
>> s:{igds_text_size} Referencing Text size column
>> a:{igds_rotation} Referencing Rotation Column
>> t:{igds_text_string}  Referencing Text String Column,
>> I then used the DXF Export tool, with no success.
>> What have I done wrong? Should I be doing this as an OGR2OGR exercise
>> as opposed to using the Export tool?
>> Regards,
>> Richard.
>> On 09/06/2016 13:10, Heikki Vesanto wrote:
>>> With ogr2org (which QGIS uses for import/export), when writing a DXF
>>> file, if you have an input point geometry, which has an OGR_STYLE
>>> attribute, it will be written as a text geometry when opened in CAD.
>>> This will work straight from a database as well. But there is a guide
>>> that uses gml at:
>>> http://gisforthought.com/gis-to-cad-using-ogr2ogr-part-3-point-annotation-to-text-in-cad/
>>> On Thu, Jun 9, 2016 at 12:30 PM, Richard McDonnell
>>> <richard.mcdonnell at opw.ie>  wrote:
>>>> Afternoon all,
>>>> I would firstly like to say that the DXF Export option is great, and is a
>>>> great addition to QGIS.
>>>> I do have one problem though which you you may be able to help with.
>>>> I have a PostGIS database LineStrings and Points (Text)
>>>> What I would like to do is have the text export also, all I get when I
>>>> export the points is....Points, no text.
>>>> I would appreciate any help, I am tying to get a Map out at the moment and
>>>> would have a preference to output it via QGIS.
>>>> Regards,
>>>> Richard.
>>>> OPW - Ag féachaint don am atá le teacht - Ag caomhnú ón am atá thart
>>>> OPW - Looking to the future - Caring for the past
>>>> Email Disclaimer:http://www.opw.ie/en/disclaimer/
>>>> _______________________________________________
>>>> Qgis-user mailing list
>>>> Qgis-user at lists.osgeo.org
>>>> List info:http://lists.osgeo.org/mailman/listinfo/qgis-user
>>>> Unsubscribe:http://lists.osgeo.org/mailman/listinfo/qgis-user
>> *_Richard McDonnell_*
>> *GIS Specialist PgD GIS AssocSCSI*
>> *OPW FRM Data Management*
>> *52 Stephens Green, Dublin 2.*
>> TEL: 01 6476543
> List info: http://lists.osgeo.org/mailman/listinfo/qgis-user
> Unsubscribe: http://lists.osgeo.org/mailman/listinfo/qgis-user
TEL: 01 6476543
URL: <http://lists.osgeo.org/pipermail/qgis-user/attachments/20160609/b5b8dbff/attachment.html>
