[Qgis-user] Crash Minidump while using Semi-Automatic Classification Plugin
Matthias Kuhn matthias at opengis.ch
Thu Jun 16 01:23:40 PDT 2016
When encountering bugs (and especially crashes) with 3rd party plugins, it's normally the best way to fill an issue report or contact the author.
The plugin itself points to the issue queue here:
http://hub.qgis.org/projects/semi-automatic-class/issues
Regards
Matthias
On 06/16/2016 09:57 AM, Akihiko Hino wrote:
> I'm a owner of this thread.
> I'd like to share one more information.
> My friend advised me that it might work on QGIS 32 bit & Win 7 32 bit.
> So, I removed .qgis2 folder in myuser folder, and installed QGIS 32bit  on
> Win7 32bit (Japanese Language) again.
> The reason why I use this Plugin is just to classify the image on QGIS.
> But when I start that module and create a ROI polygon, QGIS always hangs-up.
> I've not confirmed the all of the case that it occurs.
> Now, I'm back to QGIS 64 bit & Win 7 64 bit.
> Actually, QGIS always shows "Crash Minidump", but the classification itself
> completes successfully and the result is saved.
> View this message in context: http://osgeo-org.1560.x6.nabble.com/Crash-Minidump-while-using-Semi-Automatic-Classification-Plugin-tp5268078p5271966.html
> Sent from the Quantum GIS - User mailing list archive at Nabble.com.
> Qgis-user mailing list
> List info: http://lists.osgeo.org/mailman/listinfo/qgis-user
> Unsubscribe: http://lists.osgeo.org/mailman/listinfo/qgis-user
