[Qgis-user] best data storage fo time series visualisation in QGIS
Andrew Harfoot ajph at geodata.soton.ac.uk
Fri Jun 17 02:58:16 PDT 2016
I saw a demo of the Crayfish plugin at the FOSS4G-UK conference earlier
in the week, and it provides 'time slider' functionality for netCDF
based data, plus additional tools such as video generation. Worth taking
a look?
Andy
On 17/06/2016 10:29, Régis Haubourg wrote:
> Hi,
> I need the communities lights!
> I'm starting to work with huge meteo datasets composed of a grid of
> point layers, and hundred of millions of rainfall / temperature data.
> Datasets are delivered in a custom text format, so I'm digging around
> on what are the best formats for storage, use in postgis and QGIS.
> I would like to be able to :
>  - run timeManager to generate videos
>  - display data averaged on day / month / year (or any other) timeframe
>  - feed R analyses.
> Up to now, I tried the following paths:
>   - netcdf  / grib:  ideal for data storage:
>           Pros : GDAL and QGIS can view it. R And python scipy have
> providers for that
>           Cons : not easy to generate from exotic datasources, Current
> QGIS Netcdf explorer or core date visualisation (time frame = raster
> bands)  are not handy for daily data over decades (about 10 000 days
> available in my dataset).  I didn't manage to build netcdf yet, FME or
> GDAL are a bit dry..
>  - load all in postgres / postgis relationnal model:
>           Pros: available for all clients and fast, if data is
> correctly indexed and designed/
>           Cons: performance requires a table (not a view because of
> lack of estimated metadata for extent computing) with redondancy over
> point location. I tried a first approach with a small geographical
> table for my point grid and a value table. With correct indexing and
> clustering, I get good performance in psql but very poor in QGIS.
> First load is slooow because of the st_extent query, but also every
> fetch afterwards, even if I filter on a date frame (with good index).
> I didn't expect it to be slow on fetch..
> Another point with postgis storage, TimeManager plugin does not like
> true date datatype, date cast to char truncate date to first
> character,  so I have to expose my datasets with a text format in my
> view, which is not quite efficient.  (I will create a ticket upstream)
> *Does anyone has any experience and advices on that field ? *
>  I saw that postgis has a datacube type, could that be a way to store
> data more efficiently? Could QGIS read it? Should I stick with netcdf ?
> Thanks a lot
> Régis
> Qgis-user mailing list
> List info: http://lists.osgeo.org/mailman/listinfo/qgis-user
> Unsubscribe: http://lists.osgeo.org/mailman/listinfo/qgis-user
Andy Harfoot
GeoData Institute
University of Southampton
Southampton
SO17 1BJ
Tel:  +44 (0)23 8059 2719
Fax:  +44 (0)23 8059 2849
www.geodata.soton.ac.uk
URL: <http://lists.osgeo.org/pipermail/qgis-user/attachments/20160617/f97e8b38/attachment.html>
