[Qgis-user] Autotrace working?
DelazJ delazj at gmail.com
Wed Jun 22 03:20:36 PDT 2016
And is the snapping options active on all layers that are supposed to build
the path?
2016-06-22 12:08 GMT+02:00 DelazJ <delazj at gmail.com>:
> Hi,
> Andreas, is your next vertex reachable by the segments in the layer? I
> mean, there should not be a gap between your points.
> Harrissou
> 2016-06-22 11:58 GMT+02:00 Neumann, Andreas <a.neumann at carto.net>:
>> Hi,
>> I can't get the Autotrace digitizing tool (the magnet) to work - neither
>> in QGIS 2.14.3 nor in QGIS master. Is there a known issue?
>> It seems to snap to vertices where I click, but nothing is calculated in
>> between.
>> It's a pity - since it is really useful.
>> Here are my steps:
>> 0. Settings snapping options - 10 pixels to vertex
>> 1. Testing with Line or Polygon layer
>> 2. Start editing
>> 3. Pressing the red magnet
>> 4. placing start node
>> 5. placing in between or end nodes
>> ..> no shortest path is calculated ;-(
>> Do you have any hints what I may be doing wrong?
>> Thanks,
>> Andreas
>> Qgis-user mailing list
>> List info: http://lists.osgeo.org/mailman/listinfo/qgis-user
>> Unsubscribe: http://lists.osgeo.org/mailman/listinfo/qgis-user
URL: <http://lists.osgeo.org/pipermail/qgis-user/attachments/20160622/33f2de67/attachment.html>
