[Qgis-user] Autotrace working?
Neumann, Andreas a.neumann at carto.net
Wed Jun 22 03:42:16 PDT 2016
Hi all,
Thank you all for your ideas.
Meanwhile I found the problem: it doesn't seem to work with data
containing circular arcs (CurvePolygon, CompoundCurve, etc.). If I load
data without circular arcs it works fine.
Saber/Martin: could you estimate how much effort it would be to also
support these geometry types?
I could provide sample data with circular arcs (Geopackage, GML or
Postgis dump).
I will open an issue.
Andreas
On 2016-06-22 12:26, Saber Razmjooei wrote:
> Hi Andreas,
> Would it be possible to provide some sample data?
> Cheers,
> Saber
> FROM: Qgis-user [mailto:qgis-user-bounces at lists.osgeo.org] ON BEHALF OF DelazJ
> SENT: 22 June 2016 11:21
> TO: Neumann, Andreas
> CC: QGIS User List
> SUBJECT: Re: [Qgis-user] Autotrace working?
> And is the snapping options active on all layers that are supposed to build the path?
> 2016-06-22 12:08 GMT+02:00 DelazJ <delazj at gmail.com>:
> Hi,
> Andreas, is your next vertex reachable by the segments in the layer? I mean, there should not be a gap between your points.
> Harrissou
> 2016-06-22 11:58 GMT+02:00 Neumann, Andreas <a.neumann at carto.net>:
>> Hi,
>> I can't get the Autotrace digitizing tool (the magnet) to work - neither in QGIS 2.14.3 nor in QGIS master. Is there a known issue?
>> It seems to snap to vertices where I click, but nothing is calculated in between.
>> It's a pity - since it is really useful.
>> Here are my steps:
>> 0. Settings snapping options - 10 pixels to vertex
>> 1. Testing with Line or Polygon layer
>> 2. Start editing
>> 3. Pressing the red magnet
>> 4. placing start node
>> 5. placing in between or end nodes
>> ..> no shortest path is calculated ;-(
>> Do you have any hints what I may be doing wrong?
>> Thanks,
>> Andreas
>> Qgis-user mailing list
>> List info: http://lists.osgeo.org/mailman/listinfo/qgis-user
>> Unsubscribe: http://lists.osgeo.org/mailman/listinfo/qgis-user
> This email and any files transmitted with it are confidential and intended solely for the use of the individual or entity to whom they are addressed. If you have received this email in error please notify the system manager. This message contains confidential information and is intended only for the individual named. If you are not the named addressee you should not disseminate, distribute or copy this e-mail. Please notify the sender immediately by e-mail if you have received this e-mail by mistake and delete this e-mail from your system. If you are not the intended recipient you are notified that disclosing, copying, distributing or taking any action in reliance on the contents of this information is strictly prohibited.
> Whilst reasonable care has been taken to avoid virus transmission, no responsibility for viru ses is taken and it is your responsibility to carry out such checks as you feel appropriate.
> If this email contains a quote or offer to sell products, carry out work or perform services then our standard terms and conditions [1] shall apply unless explicitly stated otherwise.
> Saber Razmjooei and Peter Wells trading as Lutra Consulting.
Links:
[1]
http://www.lutraconsulting.co.uk/downloads/Lutra%20Consulting%20Standard%20Terms%20and%20Conditions.pdf
URL: <http://lists.osgeo.org/pipermail/qgis-user/attachments/20160622/c5e29a13/attachment.html>
