[Qgis-user] Variables in print composer
Martin Stubbs
martin at mstubbs.co.uk
Thu Jun 23 03:46:12 PDT 2016
On 23/06/16 08:30, Uwe Fischer wrote:
> Hello List,
> what is the use of variables in print composer? A map frame has
> variables assigned like map_extent_height and _width. But how to make
> use of those variables? If I try to place a rectangle around the map
> frame using the determined extent variables (plus something), I cannot
> use the variables. There is a ‚data defined override‘ section in the
> Position and size dialog for rectangles, but when I select ‚variable‘
> it tells me that there are no variables, which seems to be nonsense.
> Best regards, Uwe
Uwe,
When you select a Data_defined_override in Position and size, pick edit
from the list instead of variable. In the Expression string builder you
will find map_extent_height in the Variables list.
Regards
Martin
URL: <http://lists.osgeo.org/pipermail/qgis-user/attachments/20160623/3f272666/attachment.html>
