[Qgis-user] Variables in print composer
Junior delazj at gmail.com
Thu Jun 23 08:14:40 PDT 2016
Qd
Envoyé depuis mon HTC
----- Reply message -----
De : "Uwe Fischer" <gisfisch at t-online.de>
Pour : "'Martin Stubbs'" <martin at mstubbs.co.uk>, <qgis-user at lists.osgeo.org>
Objet : [Qgis-user] Variables in print composer
Date : jeu., juin 23, 2016 13:36
Martin, thank you very much for your tip, but in the variables list no variables of type „map“ show up (please see attachment). But in print composter they are present and visible. Mit freundlichen Grüßen, Uwe Fischer
Von: Qgis-user [mailto:qgis-user-bounces at lists.osgeo.org] Im Auftrag von Martin Stubbs
Gesendet: Donnerstag, 23. Juni 2016 12:46
An: qgis-user at lists.osgeo.org
Betreff: Re: [Qgis-user] Variables in print composer
On 23/06/16 08:30, Uwe Fischer wrote:
Hello List, what is the use of variables in print composer? A map frame has variables assigned like map_extent_height and _width. But how to make use of those variables? If I try to place a rectangle around the map frame using the determined extent variables (plus something), I cannot use the variables. There is a ‚data defined override‘ section in the Position and size dialog for rectangles, but when I select ‚variable‘ it tells me that there are no variables, which seems to be nonsense.  Best regards, Uwe Uwe,
When you select a Data_defined_override in Position and size, pick edit from the list instead of variable. In the Expression string builder you will find map_extent_height in the Variables list.
Regards
Martin
URL: <http://lists.osgeo.org/pipermail/qgis-user/attachments/20160623/9578cc1e/attachment.html>
