[Qgis-user] (poor) performance loading postgis layers in qgis-server 2.8 ltr + postgis 2.1 + lizmap web-client
Daniel Vicente Lühr Sierra
dluhr at ieee.org
Thu Jun 23 20:40:05 PDT 2016
Indeed, 2.14.3 shows a better performance with respect to serving
database data, even without yet tuning the database server.
But, I still experience some performance issues. One, I detected when
using the print composer, which is very unresponsive if there is a map
object with a big database layer and redrawing is needed (without
drawing the map, the UI responds fine).
Second, the webclient layers load in decent time, even the "big-one".
But, trying to use lizmap's "tooltip" feature on the big layer, or
trying to access its attribute table is still not possible. I haven't
checked the code, but maybe the way the data is being requested in these
situations is suboptimal?
Regards
El 21/06/16 a las 11:08, Daniel Vicente Lühr Sierra escribió:
> Hi Régis,
> El 21/06/16 a las 10:37, Régis Haubourg escribió:
>> Hi,
>> please see that thread [0]
> Thanks.
>> I suggest you first upgrade qgis server to last 2.14.3.
> Ok, some weeks ago I decided to stay with 2.8 ltr, until 2.14 was more
> tested, it looks like it is time for upgrading.
>> Then we still have issues with big relational views, not tables - for
>> first getcapabilities generation (ie first load for a session).
>> You can also check your postgres logs to look at what queries are
>> sent to PG and then tune your pg server based on those queries.
> Ok. Although, I still need to learn how to do it ...
>> Please keep us informed of how it works, we have the very same concerns.
> Sure, thanks again.
>> [0] http://osgeo-org.1560.x6.nabble.com/Server-performance-questions-td5252233i20.html#a5268188
>> 2016-06-21 16:29 GMT+02:00 Daniel Vicente Lühr Sierra <dluhr at ieee.org>:
>> Hi,
>> It is my first time at setting up a postgres/PostGIS db for
>> storing "serious" data (previously, I had only tested if it
>> worked, with a couple of small data tables).
>> When testing the web-client (lizmap) installation I noticed that
>> the sample data loaded pretty fast, but when I tried a project
>> containing 2 vector layers stored in the database, one very
>> small, the second one was originally a ~30Mb shape file, the
>> loading process for the 2 layers is noticeable, and reading the
>> attribute table of the big vector layer (only 20 rows and 10
>> fields) takes ages (actually, I wasn't able to wait for it to load).
>> I did some "google" research and found out that there might be
>> some performance issues on qgis-server when accessing postgresql
>> layer, or it could be that the performance of the db is low (I
>> haven't run the tuning utility, yet).
>> Any ideas on how to hunt down this performance issue? May it be
>> an issue with the web-client, also?
>> Btw, everything is running locally on a VM for now, although the
>> final deployment will be on "real" hardware.
>> Thanks
>> IEEE Member
>> IEEE Student Branch Counselor - Universidad Austral de Chile
>> Qgis-user mailing list
>> Qgis-user at lists.osgeo.org <mailto:Qgis-user at lists.osgeo.org>
>> List info: http://lists.osgeo.org/mailman/listinfo/qgis-user
>> Unsubscribe: http://lists.osgeo.org/mailman/listinfo/qgis-user
>> Régis Haubourg
>> Attention, changement d'adresse mail!
>> Mon adresse principale devient désormais regis.haubourg at gmail.com
>> <http://gmail.com>
> IEEE Member
IEEE Member
URL: <http://lists.osgeo.org/pipermail/qgis-user/attachments/20160623/323f7d64/attachment.html>
