[Qgis-user] QGis not running windows 7
Nicolas Cadieux nicolas.cadieux at archeotec.ca
Mon Jun 27 07:41:10 PDT 2016
I would try installing in another similar machine to see if you can reproduce the problem. You could destroy the current .qgis2 folder. It should be recreated on start up.
Try the easy install.  I would write down everything you have done and make a need posts.  You could log a formal bug report.
You could try Osgeo live DVD. For a Linux install without actually installing Linux in the meantime.
Good luck
Nicolas
On Jun 27, 2016 10:16, "defelix [via OSGeo.org]" <ml-node+s1560n5273571h62 at n6.nabble.com> wrote:
	I made sure that there is not .qgis2 hidden folder before to install the new version, so I think it is not that the issue.
I also tried changing environments variable path, no success! Moreover I cannot reinstall windows since this would mean to start from the scratch for too many sofwares, it is the corporate machine, it wounld't make sense to do that.
I neeed to ask if exists a log in case of crashes.
				Defelix
		If you reply to this email, your message will be added to the discussion below:
		http://osgeo-org.1560.x6.nabble.com/QGis-not-running-windows-7-tp5273169p5273571.html
		To start a new topic under Quantum GIS - User, email ml-node+s1560n4125267h38@n6.nabble.com
		To unsubscribe from Quantum GIS - User, click here .
		NAML
View this message in context: http://osgeo-org.1560.x6.nabble.com/QGis-not-running-windows-7-tp5273169p5273581.html
Sent from the Quantum GIS - User mailing list archive at Nabble.com.
URL: <http://lists.osgeo.org/pipermail/qgis-user/attachments/20160627/5572fc27/attachment.html>
