[Qgis-user] QGis not running windows 7
Nicolas Cadieux
nicolas.cadieux at archeotec.ca
Tue Jun 28 08:28:06 PDT 2016
If you have teamviewer, maybe I could log on to your machine and see if I can spot something. You would will need to have the admin password. That could be problematic in an office. You could set up a temporary admin if they don't like that.
I am in Montréal.
Nicolas
On Jun 27, 2016 11:04, "defelix [via OSGeo.org]" <ml-node+s1560n5273589h20 at n6.nabble.com> wrote:
just a small clue I found out, in a file named setup.log.full in the following folder C:\OSGeo4W64\var\log I found this row:
2016/06/27 13:08:10 error: Environment variable 'PATH' length exceeds 1024; running with %WINDIR%\system32;%WINDIR%;%WINDIR%\wbem
I don't know if would help, maybe it is important.
Defelix
If you reply to this email, your message will be added to the discussion below:
http://osgeo-org.1560.x6.nabble.com/QGis-not-running-windows-7-tp5273169p5273589.html
To start a new topic under Quantum GIS - User, email ml-node+s1560n4125267h38@n6.nabble.com
To unsubscribe from Quantum GIS - User, click here .
NAML
View this message in context: http://osgeo-org.1560.x6.nabble.com/QGis-not-running-windows-7-tp5273169p5273793.html
Sent from the Quantum GIS - User mailing list archive at Nabble.com.
URL: <http://lists.osgeo.org/pipermail/qgis-user/attachments/20160628/a13b5de7/attachment.html>
