[Qgis-user] regularly spaced address markers on alternating side of road
Neumann, Andreas
a.neumann at carto.net
Wed Jun 29 00:17:28 PDT 2016
Hi Dan,
This is not true - you can switch to map units everywhere there is a
distance property.
Andreas
On 2016-06-29 09:12, Dan Jacobson wrote:
> OK I have determined that everything in the Layer Properties menus
> (style etc.) I should NOT use, because they are all millimeter based
> (and will not change with what scale I print the map at.) And I should
> instead look at the degree and meter based plugins like Qchainage.
URL: <http://lists.osgeo.org/pipermail/qgis-user/attachments/20160629/fbc57bc5/attachment.html>
