[Qgis-user] help
Brent Wood pcreso at yahoo.com
Thu Jun 30 17:00:26 PDT 2016
To run programs compiled with MS Visual C++, you need the MS runtime libraries -
This might help - it is a well known & common issue with lots of programmes - I thought QGIS included them as part of the install, but could be wrong.
https://www.native-instruments.com/en/support/knowledge-base/show/2399/windows-error-message-missing-msvcp120.dll-file/
I don't use Windows so don't have this problem :-)
Cheers,
  Brent Wood
      From: M.I. Sergio Lozano Torres <slozanot at cenapred.unam.mx>
 To: qgis-user at lists.osgeo.org
 Sent: Friday, July 1, 2016 11:42 AM
 Subject: [Qgis-user] help
<!--#yiv1321858035 _filtered #yiv1321858035 {font-family:Calibri;panose-1:2 15 5 2 2 2 4 3 2 4;} _filtered #yiv1321858035 {font-family:Tahoma;panose-1:2 11 6 4 3 5 4 4 2 4;}#yiv1321858035 #yiv1321858035 p.yiv1321858035MsoNormal, #yiv1321858035 li.yiv1321858035MsoNormal, #yiv1321858035 div.yiv1321858035MsoNormal {margin:0cm;margin-bottom:.0001pt;font-size:11.0pt;font-family:"Calibri", "sans-serif";}#yiv1321858035 a:link, #yiv1321858035 span.yiv1321858035MsoHyperlink {color:blue;text-decoration:underline;}#yiv1321858035 a:visited, #yiv1321858035 span.yiv1321858035MsoHyperlinkFollowed {color:purple;text-decoration:underline;}#yiv1321858035 p.yiv1321858035MsoPlainText, #yiv1321858035 li.yiv1321858035MsoPlainText, #yiv1321858035 div.yiv1321858035MsoPlainText {margin:0cm;margin-bottom:.0001pt;font-size:11.0pt;font-family:"Calibri", "sans-serif";}#yiv1321858035 p.yiv1321858035MsoAcetate, #yiv1321858035 li.yiv1321858035MsoAcetate, #yiv1321858035 div.yiv1321858035MsoAcetate {margin:0cm;margin-bottom:.0001pt;font-size:8.0pt;font-family:"Tahoma", "sans-serif";}#yiv1321858035 span.yiv1321858035EstiloCorreo17 {font-family:"Calibri", "sans-serif";color:windowtext;}#yiv1321858035 span.yiv1321858035TextodegloboCar {font-family:"Tahoma", "sans-serif";}#yiv1321858035 span.yiv1321858035TextosinformatoCar {font-family:"Calibri", "sans-serif";}#yiv1321858035 .yiv1321858035MsoChpDefault {font-family:"Calibri", "sans-serif";} _filtered #yiv1321858035 {margin:70.85pt 3.0cm 70.85pt 3.0cm;}#yiv1321858035 div.yiv1321858035WordSection1 {}-->I would appreciate to be helped in the installation of QGis, since even I succeeded in doing so, when I try to initiate QGI, I get the message (translated from spanish): "The program con not be initiated because MSVCP120 is missing in the computer. Try to reinstall the program so to correct this problem" .Thanks,Sergio
Qgis-user mailing list
Qgis-user at lists.osgeo.org
List info: http://lists.osgeo.org/mailman/listinfo/qgis-user
Unsubscribe: http://lists.osgeo.org/mailman/listinfo/qgis-user
URL: <http://lists.osgeo.org/pipermail/qgis-user/attachments/20160701/747a7085/attachment.html>
