[Qgis-user] Layer driven Atlas
Andreas Neumann a.neumann at carto.net
Tue Mar 1 12:12:13 PST 2016
Hi Thomas,
You will need a table with a record per page for the atlas coverage layer.
So if, f.e. you have a table with administrative units (with geometries)
and a table with temporal layers (e.g. an ortho-image every 5 years or
so) you will need to do a cross-join between the two tables.
See http://www.tutorialspoint.com/sqlite/sqlite_using_joins.htm
You can use the new Virtual layer feature from QGIS 2.14 to create such
a layer on-the-fly without having to store a separate layer. Let us know
if you need help on the virtual layer.
Hope this helps,
Andreas
On 01.03.2016 16:58, Thomas Colley wrote:
> Hi everyone
> I was just looking through the changelogs and got really excited when
> I saw data defined control over map layers!
> (http://www.qgis.org/en/site/forusers/visualchangelog212/index.html#feature-data-defined-control-over-map-layers-and-style-presets)
> This is exactly what I’d been asking about on the list last year
> (http://lists.osgeo.org/pipermail/qgis-user/2015-August/033211.html)
> so thanks so much to Nyall for adding this functionality!
> I’m not 100% sure that I’m using it in the correct way though. I have
> managed to achieve it by duplicating my atlas coverage features so
> that there is one feature per layer with an attribute holding the
> layer name. I then use the attribute in the data defined layers option.
> Is this the way to do it or am I missing something? I wasn’t sure
> where/if the ‘set layer list from a visibility preset’ should come
> into play.
> When I first read the post I thought that the | separated list of
> layers would be cycled through one by one but then realised that
> they’d all be displayed together.
> I have a static list of 20 or so layers to cycle through for each site
> so ideally if I could specify a list of layers (or visibility presets)
> to loop through that would be amazing.
> Failing that I can write a little plugin to take a selected feature
> and create a scratch layer with the feature duplicated with the layer
> attribute values.
> Thanks again for adding this, it’ll be a massive time saver for us!
> Tom
> Qgis-user mailing list
> List info: http://lists.osgeo.org/mailman/listinfo/qgis-user
> Unsubscribe: http://lists.osgeo.org/mailman/listinfo/qgis-user
URL: <http://lists.osgeo.org/pipermail/qgis-user/attachments/20160301/d9c80ee3/attachment.html>
