[Qgis-user] force data type in QTableWidget in QGIS plugin
matteo matteo.ghetta at gmail.com
Wed Mar 2 07:46:04 PST 2016
> I assume that it's just saved as a string when you fill it in designer?
exactly.. I filled the table cells with numbers that are "translated" in
strings by Qt.
> So in this case you will need to check the value itself (with tricks
> like casting to an integer and if unsuccessful casting to a float or
> similar).
ah ok.. I hoped for something easier :)
so there is no way (in Designer) to prevent the column for different
values? I mean, I want that in the first column you can add just Int and
not floats.
Thanks again Matthias
Cheers
Matteo
