[Qgis-user] OpenGeo QGIS webappbuilder plugin error
Hanlie Pretorius hanlie.pretorius at gmail.com
Fri Mar 4 05:00:52 PST 2016
Thanks for helping.
OpenGeo Suite version 4.8
webappbuilder plugin version
0.1-20150803-745BF17B0B05A4BB9447E0899FCA2BB66AEAD4E
processing plugin version 2.12.2
For the last one the error message is:
This plugin is incompatible with this version of QGIS
Plugin designed for QGIS 2.12 - 2.99
The OpenGeo QGIS version is 2.8.3, so I guess I should try replacing
the processing viewer with version 2.10.3.
https://plugins.qgis.org/plugins/processing/
Will try that and let you know how it turns out.
2016-03-04 14:52 GMT+02:00, Luigi Pirelli <luipir at gmail.com>:
> Hi Hanlie
> glad you are learning OpenGeo
> I would ask you more info about the problem
> webappbuilder plugin version (from plugin manager)
> and
> processing plugin version (from plugin manager)
> regards
> Luigi Pirelli
> * Boundless QGIS Support/Development: lpirelli AT boundlessgeo DOT com
> * LinkedIn: https://www.linkedin.com/in/luigipirelli
> * Stackexchange: http://gis.stackexchange.com/users/19667/luigi-pirelli
> * GitHub: https://github.com/luipir
> * Mastering QGIS:
> https://www.packtpub.com/application-development/mastering-qgis
> On 4 March 2016 at 13:29, Hanlie Pretorius <hanlie.pretorius at gmail.com>
> wrote:
>> Hi,
>> I'm working on Windows 8.1.
>> I have downloaded and installed QGIS for OpenGeo and the webappbuilder
>> plugin fails to load with the following error:
>> Couldn't load plugin webappbuilder due to an error when calling its
>> classFactory() method"
>> All the information I could find on the web about this error have not
>> helped me.
>> In the Plugin Manager the Uninstall plugin and Reinstall plugin
>> buttons are disabled. It shows a message:
>> This plugin is broken
>> cannot import name show_message_log
>> I have uninstalled and reinstalled OpenGeo QGIS several times but it
>> makes no difference.
>> Does someone know how to fix this plugin? I would really like to use
>> it to start learning how to use OpenGeo.
>> Thanks
>> Hanlie
>> Qgis-user mailing list
>> List info: http://lists.osgeo.org/mailman/listinfo/qgis-user
>> Unsubscribe: http://lists.osgeo.org/mailman/listinfo/qgis-user
