[Qgis-user] Export SHP to mySQL
Vicent García vicent_montesa at hotmail.com
Sat Mar 5 13:32:30 PST 2016
Ok!
Thanks to everyone!
Vicent.
De: Qgis-user [mailto:qgis-user-bounces at lists.osgeo.org] En nombre de Marco Lechner - FOSSGIS e.V.
Enviado el: dissabte, 5 de març de 2016 16:51
Para: qgis-user at lists.osgeo.org
Asunto: Re: [Qgis-user] Export SHP to mySQL
read this:
https://dev.mysql.com/doc/refman/5.7/en/creating-spatial-indexes.html
Marco
Am 05.03.2016 um 14:55 schrieb Vicent García:
I’ve tried to do that (shp2mysql), but I got this error:
“ERROR 1: MySQL error message: The used table type doesn’t suport SPATIAL indexes. Description: ALTER TABLE ‘shapefile’ ADD SPATIAL INDEX(‘poligon_columna’)
ERROR 1: Terminating translation prmaturely after failed translation of layer ESP_adm4 (use -skipfailures to skip errors)”
Sorry, but it’s my first time that I use this command and I’m a bit lost.
Thanks,
Vicent.
Enviado el: dissabte, 5 de març de 2016 11:16
Para: qgis-user at lists.osgeo.org <mailto:qgis-user at lists.osgeo.org>
Hi Vincent,
its possible using ogr2ogr (and should be possible using QGIS -> Layer save as ... as well.
# shp2mysql
ogr2ogr -f MySQL MySQL:<my_db>,user=<username>,password=<mypass> <path2shape>.shp -nln <target_table> -overwrite -update -lco GEOMETRY_NAME=geom -lco ENGINE=MyISAM -lco CHARSET=UTF-8
# info about table
ogrinfo MySQL:<my_db>,user=<username>,password=<mypass> <table_name> -so
# mysql2shp
ogr2ogr -f "ESRI Shapefile" <path2shape>.shp MySQL:<my_db>,user=<username>,password=<mypass> -sql "SELECT * from <my_table>"
Hope this helps
Marco
Am 05.03.2016 um 08:32 schrieb Vicent García:
Hi Community,
Does anyone know how to export shapefile files to mySQL? I read some things about the topic on the Internet but no clear solutions I’ve found.
Thanks,
Vicent.
Qgis-user mailing list
Qgis-user at lists.osgeo.org <mailto:Qgis-user at lists.osgeo.org>
List info: http://lists.osgeo.org/mailman/listinfo/qgis-user
Unsubscribe: http://lists.osgeo.org/mailman/listinfo/qgis-user
URL: <http://lists.osgeo.org/pipermail/qgis-user/attachments/20160305/7ef0f7d1/attachment.html>
