[Qgis-user] qgis - virtual layers
    Jozef Riha
    jose1711 at gmail.com
    Sat Mar  5 15:31:54 PST 2016
hello list,
not sure if this is a known problem but during virtual layers feature
testing i discovered that this tool has issues when source used in query
contains characters such as space, forward slash, dash and possibly others
in column names. it would be nice if user would be presented with a
meaningful error message rather than a cryptic message about syntax error.
to reproduce:
- import test.geojson to qgis
- add virtual layer - run select * from test
- you'll get:
Query execution error on DROP TABLE IF EXISTS "test"; CREATE VIRTUAL TABLE
"test" USING QgsVLayer(test20160305235656402);: 1 - near "1": syntax error
br, j
URL: <http://lists.osgeo.org/pipermail/qgis-user/attachments/20160306/b724497f/attachment.html>
Type: application/octet-stream
Desc: not available
URL: <http://lists.osgeo.org/pipermail/qgis-user/attachments/20160306/b724497f/attachment.obj>
