[Qgis-user] R in QGIS on OSX using Kyngchaos build
Agustin Diez-Castillo gvsig.mac at gmail.com
Mon Mar 7 10:38:04 PST 2016
Thanks for pointing me in the right direction. Following instructions at the grass for mac wikidot I've disabled [1] the System Integrity Protection feature and later on I’ve linked my R and Rscript at /usr/local/bin to /usr/bin
sudo ln -s /usr/local/bin/R
sudo ln -s /usr/local/bin/Rscript Rscript
Now R is working from Qgis at el Capitan
Merci
PS Maybe is a good idea to put the trick at the Qgis wiki.
 [1] http://grassmac.wikidot.com
> On 07 Mar 2016, at 18:43, gene <martin.laloux at gmail.com> wrote:
> The test is done in the lines 179-200 in the script Rutils.py.  It consists
> in running the shell command
> command = ['R --version'] with processing
> proc = subprocess.Popen(
>            command,
>            shell=True,
>            stdout=subprocess.PIPE,
>            stdin=open(os.devnull),
>            stderr=subprocess.STDOUT,
>            universal_newlines=True,
>        ).stdout
> for line in iter(proc.readline, ''):
>    if 'R version' in line:
>         settings.setValue(R_INSTALLED, True)
>         return
> The result in my  shell is
> $ R --version
> WARNING: ignoring environment value of R_HOME
> R version 3.2.2 (2015-08-14) -- "Fire Safety"
> Copyright (C) 2015 The R Foundation for Statistical Computing
> Platform: x86_64-apple-darwin13.4.0 (64-bit)
> Therefore, it is an R problem with El Capitan and not a Kyngchaos build
> problem
> The problem of El Capitan is that only Apple is allowed to install software
> under /usr/bin (only /usr/local/bin)  and the R (R, Rscript) executables are
> in  /usr/bin. This affects also MacTeX and XQuartz (because of the new
> System Integrity Protection  (SIP)
> <https://support.apple.com/en-us/HT204899>  )
> Therefore, it is an R problem and not a Kyngchaos build  problem ( the
> problem of R with El Capitan  has been resolved)
> View this message in context: http://osgeo-org.1560.x6.nabble.com/R-in-QGIS-on-OSX-using-Kyngchaos-build-tp5254567p5254940.html
> Sent from the Quantum GIS - User mailing list archive at Nabble.com.
> Qgis-user mailing list
> List info: http://lists.osgeo.org/mailman/listinfo/qgis-user
> Unsubscribe: http://lists.osgeo.org/mailman/listinfo/qgis-user
URL: <http://lists.osgeo.org/pipermail/qgis-user/attachments/20160307/8e85585b/attachment.html>
