[Qgis-user] Plugin processing problem
Nathan Woodrow madmanwoo at gmail.com
Thu Mar 17 04:53:26 PDT 2016
What is in {QGIS Install folder}\apps\qgis\python\plugins
e.g C:\OSGeo4W\apps\qgis\python\plugins
Is there a processing folder in there?
What is in .qgis2\python\plugins?
On Thu, Mar 17, 2016 at 9:48 PM, Lene Fischer <lfi at ign.ku.dk> wrote:
> YES!!!!!!!
> We have the same problem. One of my students are right at this moment
> sitting in the class. Installing – re-installing- deleting – REGEDIT
> The same problem – Processing missing.
> We now wail for the last installation – pray and hope it will work.
> Regards
> Lene Fischer
> *Fra:* Qgis-user [mailto:qgis-user-bounces at lists.osgeo.org] *På vegne af *
> McDonaldR
> *Sendt:* 17. marts 2016 12:23
> *Til:* qgis-user at lists.osgeo.org
> *Emne:* [Qgis-user] Plugin processing problem
> Hello List
> Every time I open QGIS Essen I get an error message telling me that the
> Plugin processing will be disabled because it crashed QGIS during the last
> startup. Please report an issue and re-enable the plugin when the problem
> has been resolved.
> The processing plugin is not enabled.  I have version 2.12.2 installed.
> Once QGIS is ready I can enable the processing plugin and open the
> processing toolbox (the search is slow as has been pointed out in other
> mails and issues).
> Has anyone else experienced this and can you recommend a fix?
> I am running QGIS 2.14 on Windows 7 Pro 32bit.
> 2016-03-17T10:13:23 0 QGIS starting...
> 2016-03-17T10:14:19 0 Python support ENABLED :-)
> 2016-03-17T10:17:35 0 Application state:
> QGIS_PREFIX_PATH env var: C:/OSGeo4W/apps/qgis
> Prefix: C:/OSGeo4W/apps/qgis
> Plugin Path: C:/OSGeo4W/apps/qgis/plugins
> Package Data Path: C:/OSGeo4W/apps/qgis/.
> Active Theme Name: default
> Active Theme Path: C:/Users/hdumpty/.qgis2///themes\default\icons/
> Default Theme Path: :/images/themes/default/
> SVG Search Paths: \\dcnasfs\gis\QGIS\Styles\svg
> C:/OSGeo4W/apps/qgis/./svg/
> C:/Users/hdumpty/.qgis2//svg/
> User DB Path: C:/OSGeo4W/apps/qgis/./resources/qgis.db
> Auth DB Path: C:/Users/hdumpty/.qgis2//qgis-auth.db
> 2016-03-17T10:17:35 0 QGIS Ready!
> Thanks
> Ross
> *Ross McDonald *| GIS Data Coordinator | Resources Department, IT
> Division | Angus Council, Angus House, Orchardbank Business Park, Forfar,
> DD8 1AT
> T: *01307 476419* | F: 01307 476401 | E: mcdonaldr at angus.gov.uk
> This message is strictly confidential. If you have received this in error,
> please inform the sender and remove it from your system. If received in
> error you may not copy, print, forward or use it or any attachment in any
> way. This message is not capable of creating a legal contract or a binding
> representation and does not represent the views of Angus Council. Emails
> may be monitored for security and network management reasons. Messages
> containing inappropriate content may be intercepted. Angus Council does not
> accept any liability for any harm that may be caused to the recipient
> system or data on it by this message or any attachment.
> Qgis-user mailing list
> List info: http://lists.osgeo.org/mailman/listinfo/qgis-user
> Unsubscribe: http://lists.osgeo.org/mailman/listinfo/qgis-user
URL: <http://lists.osgeo.org/pipermail/qgis-user/attachments/20160317/ce6b40d6/attachment.html>
