[Qgis-user] Plugin processing problem
Luigi Pirelli luipir at gmail.com
Thu Mar 17 05:25:25 PDT 2016
May I suggest you to remove
C:\Users\mcdonaldr\.qgis2\python\plugins\processing folder ?
I suppose you have an old processing version (loaded after default
core processing in C:\OSGeo4W\apps\qgis\python\plugins\processing)
that conflict with 2.14 => it is disabled (that in
C:\Users\mcdonaldr\.qgis2\python\plugins\processing).
But the core one still remain loaded correctly.
let us know
p.s before to remove
C:\Users\mcdonaldr\.qgis2\python\plugins\processing, what is the
content of C:\Users\mcdonaldr\.qgis2\python\plugins\processing\metadata.txt
Luigi Pirelli
* Boundless QGIS Support/Development: lpirelli AT boundlessgeo DOT com
* LinkedIn: https://www.linkedin.com/in/luigipirelli
* Stackexchange: http://gis.stackexchange.com/users/19667/luigi-pirelli
* GitHub: https://github.com/luipir
* Mastering QGIS:
https://www.packtpub.com/application-development/mastering-qgis
> Db_manager
> fTools
> GdalTools
> MetaSearch
> Processing
> Processing Metadata.txt file has the following in it:
> [general]
> name=Processing
> description=Spatial data processing framework for QGIS
> about=Spatial data processing framework for QGIS
> category=Analysis
> version=2.12.99
> qgisMinimumVersion=2.13
> Gazetteersearch
> pgRoutingLayer
> processing
> processing metadata.txt has the following:
> [general]
> name=Processing
> category=Analysis
> version=2.12.2
> qgisMinimumVersion=2.12
> From: Nathan Woodrow [mailto:madmanwoo at gmail.com]
> Sent: 17 March 2016 11:53
> To: Lene Fischer
> Cc: McDonaldR; qgis-user at lists.osgeo.org
> Subject: Re: [Qgis-user] Plugin processing problem
> What is in {QGIS Install folder}\apps\qgis\python\plugins
> e.g C:\OSGeo4W\apps\qgis\python\plugins
> Is there a processing folder in there?
> What is in .qgis2\python\plugins?
> On Thu, Mar 17, 2016 at 9:48 PM, Lene Fischer <lfi at ign.ku.dk> wrote:
> YES!!!!!!!
> We have the same problem. One of my students are right at this moment
> sitting in the class. Installing – re-installing- deleting – REGEDIT
> The same problem – Processing missing.
> We now wail for the last installation – pray and hope it will work.
> Regards
> Lene Fischer
> Fra: Qgis-user [mailto:qgis-user-bounces at lists.osgeo.org] På vegne af
> McDonaldR
> Sendt: 17. marts 2016 12:23
> Til: qgis-user at lists.osgeo.org
> Emne: [Qgis-user] Plugin processing problem
> Hello List
> Every time I open QGIS Essen I get an error message telling me that the
> Plugin processing will be disabled because it crashed QGIS during the last
> startup. Please report an issue and re-enable the plugin when the problem
> has been resolved.
> The processing plugin is not enabled.  I have version 2.12.2 installed.
> Once QGIS is ready I can enable the processing plugin and open the
> processing toolbox (the search is slow as has been pointed out in other
> mails and issues).
> Has anyone else experienced this and can you recommend a fix?
> I am running QGIS 2.14 on Windows 7 Pro 32bit.
> 2016-03-17T10:13:23 0 QGIS starting...
> 2016-03-17T10:14:19 0 Python support ENABLED :-)
> 2016-03-17T10:17:35 0 Application state:
> QGIS_PREFIX_PATH env var: C:/OSGeo4W/apps/qgis
> Prefix: C:/OSGeo4W/apps/qgis
> Plugin Path: C:/OSGeo4W/apps/qgis/plugins
> Package Data Path: C:/OSGeo4W/apps/qgis/.
> Active Theme Name: default
> Active Theme Path: C:/Users/hdumpty/.qgis2///themes\default\icons/
> Default Theme Path: :/images/themes/default/
> SVG Search Paths: \\dcnasfs\gis\QGIS\Styles\svg
> C:/OSGeo4W/apps/qgis/./svg/
> C:/Users/hdumpty/.qgis2//svg/
> User DB Path: C:/OSGeo4W/apps/qgis/./resources/qgis.db
> Auth DB Path: C:/Users/hdumpty/.qgis2//qgis-auth.db
> 2016-03-17T10:17:35 0 QGIS Ready!
> Thanks
> Ross
> Ross McDonald | GIS Data Coordinator | Resources Department, IT Division |
> Angus Council, Angus House, Orchardbank Business Park, Forfar, DD8 1AT
> T: 01307 476419 | F: 01307 476401 | E: mcdonaldr at angus.gov.uk
> This message is strictly confidential. If you have received this in error,
> please inform the sender and remove it from your system. If received in
> error you may not copy, print, forward or use it or any attachment in any
> way. This message is not capable of creating a legal contract or a binding
> representation and does not represent the views of Angus Council. Emails may
> be monitored for security and network management reasons. Messages
> containing inappropriate content may be intercepted. Angus Council does not
> accept any liability for any harm that may be caused to the recipient system
> or data on it by this message or any attachment.
> Qgis-user mailing list
> List info: http://lists.osgeo.org/mailman/listinfo/qgis-user
> Unsubscribe: http://lists.osgeo.org/mailman/listinfo/qgis-user
