[Qgis-user] Plugin processing problem
Matthias Kuhn matthias at opengis.ch
Thu Mar 17 07:24:02 PDT 2016
Hmpf
from PyQt4.QtCore import QSettings
QSettings().remove('/PythonPlugins/watchDog/processing')
Shouldn't try to answer emails and fix bugs at the same time. At least
the second task was more successful. It's fixed in master and 2.14.1,
when re-enabling a plugin was successful it will be unflagged.
Matthias
On 03/17/2016 02:52 PM, Matthias Kuhn wrote:
> Sorry I meant to write
> import QSettings()
> Matthias
> On 03/17/2016 02:50 PM, Matthias Kuhn wrote:
>> Hi Ross,
>> can you run
>> import QSettings()
>> QSettings().remove('/Plugins/watchDog/processing')
>> in the python console and report back if this fixes the issue?
>> Matthias
>> On 03/17/2016 12:22 PM, McDonaldR wrote:
>>> Hello List
>>> Every time I open QGIS Essen I get an error message telling me that
>>> the Plugin processing will be disabled because it crashed QGIS
>>> during the last startup. Please report an issue and re-enable the
>>> plugin when the problem has been resolved.
>>> The processing plugin is not enabled.  I have version 2.12.2
>>> installed.  Once QGIS is ready I can enable the processing plugin
>>> and open the processing toolbox (the search is slow as has been
>>> pointed out in other mails and issues).
>>> Has anyone else experienced this and can you recommend a fix?
>>> I am running QGIS 2.14 on Windows 7 Pro 32bit.
>>> 2016-03-17T10:13:23 0 QGIS starting...
>>> 2016-03-17T10:14:19 0 Python support ENABLED :-)
>>> 2016-03-17T10:17:35 0 Application state:
>>> QGIS_PREFIX_PATH env var: C:/OSGeo4W/apps/qgis
>>> Prefix: C:/OSGeo4W/apps/qgis
>>> Plugin Path: C:/OSGeo4W/apps/qgis/plugins
>>> Package Data Path: C:/OSGeo4W/apps/qgis/.
>>> Active Theme Name: default
>>> Active Theme Path: C:/Users/hdumpty/.qgis2///themes\default\icons/
>>> Default Theme Path: :/images/themes/default/
>>> SVG Search Paths: \\dcnasfs\gis\QGIS\Styles\svg
>>> C:/OSGeo4W/apps/qgis/./svg/
>>> C:/Users/hdumpty/.qgis2//svg/
>>> User DB Path: C:/OSGeo4W/apps/qgis/./resources/qgis.db
>>> Auth DB Path: C:/Users/hdumpty/.qgis2//qgis-auth.db
>>> 2016-03-17T10:17:35 0 QGIS Ready!
>>> Thanks
>>> Ross
>>> *Ross McDonald *|**GIS Data Coordinator | Resources Department, IT
>>> Division | Angus Council, Angus House, Orchardbank Business Park,
>>> Forfar, DD8 1AT
>>> T: *01307 476419* | F: 01307 476401 | E:
>>> <mailto:mcdonaldr at angus.gov.uk>mcdonaldr at angus.gov.uk **
>>> This message is strictly confidential. If you have received this in
>>> error, please inform the sender and remove it from your system. If
>>> received in error you may not copy, print, forward or use it or any
>>> attachment in any way. This message is not capable of creating a
>>> legal contract or a binding representation and does not represent
>>> the views of Angus Council. Emails may be monitored for security and
>>> network management reasons.Messages containing inappropriate content
>>> may be intercepted. Angus Council does not accept any liability for
>>> any harm that may be caused to the recipient system or data on it by
>>> this message or any attachment.
>>> Qgis-user mailing list
>>> Qgis-user at lists.osgeo.org
>>> List info: http://lists.osgeo.org/mailman/listinfo/qgis-user
>>> Unsubscribe: http://lists.osgeo.org/mailman/listinfo/qgis-user
>> Matthias Kuhn
>> OPENGIS.ch - https://www.opengis.ch
>> Spatial • (Q)GIS • PostGIS • Open Source
> Matthias Kuhn
Matthias Kuhn
URL: <http://lists.osgeo.org/pipermail/qgis-user/attachments/20160317/aecc35cc/attachment.html>
