[Qgis-user] Atlas: Filter Empty Pages
Karl-Magnus Jönsson Karl-Magnus.Jonsson at kristianstad.se
Tue Mar 22 23:27:47 PDT 2016
Hi!
QGIS likes to have something unique. Try to add something like this in your select statement. This is a snippet from a view I made that works:
	SELECT row_number() OVER (ORDER BY o.id, s.id) AS uid,
   	 s.id,
Row_number creates a counter and then you have to decide the order in "OVER()". o.id and s.id is just what I use to sort on in my tables.
Karl-Magnus Jönsson │GIS-utvecklare
Miljö- och samhällsbyggnadsförvaltningen, avd. Geografisk information
Kristianstads kommun
291 80 Kristianstad
Besöksadress: Västra Storgatan 12
Tel 044-13 54 16 │ Mobil: 0733-13 54 16 │karl-magnus.jonsson at kristianstad.se
www.kristianstad.se
-----Ursprungligt meddelande-----
Från: Qgis-user [mailto:qgis-user-bounces at lists.osgeo.org] För Albin Blaschka
Skickat: den 22 mars 2016 15:59
Till: qgis-user at lists.osgeo.org
Ämne: Re: [Qgis-user] Atlas: Filter Empty Pages
Hello!
So, finally, I was successful: The idea with the virtual layer made it simple, as the point data is a postgis layer anyway, after storing the grid in the database, I created a view, where I have my grid and the count of points per cell, which I use for the creation of the atlas.
Brings other advantages as well... (...wondering why I had this idea not
earlier...)
The only caveat was that QGIS did not want to load the view as layer directly - It said, the layer is not valid. But after doing a "select * from myview" in the DB-Manager and adding the result as layer, it worked. Will look into it later...
(Postgres 9.4.6, PostGIS 2.1, pretty standard Ubuntu server - QGIS 2.14 on Win7 - maybe somebody has an idea on that, too?)
Thank you all for your help and specially Andreas!
best regards,
Albin
Am 21.03.2016 um 17:00 schrieb Andreas Neumann:
> hm - actually, I was wrong.
> It is not so easy to filter dynamically - as $geometry equals
> @atlas_geometry and you don't have a relation with the points.
> My next try would be to use a "Virtual Layer" and add a spatial
> relationship between your atlas coverage layer (the grid) and a column
> containing the count of points within the atlas feature.
> See
> https://www.qgis.org/en/site/forusers/visualchangelog214/index.html#fe
> ature-virtual-layers
> You need QGIS 2.14 to use the virtual layers.
> You can add a virtual column to the atlas coverage layer that uses a
> spatial relation, group by and count. If the count is zero you can
> filter that coverage feature away.
> This should hopefully work. Let us know if you are stuck.
> Andreas
> On 21.03.2016 16:41, Andreas Neumann wrote:
>> Hi Albin,
>> You can do this dynamically. The Atlas filter also accepts geometry
>> relationship functions. Have a look at the QGIS expression editor.
>> You can try with the intersects / within / overlaps tests and test
>> $geometry against @atlas_geometry.
>> Your filter could look like:
>> within( $geometry,  @atlas_geometry )
>> Can you please report back if that works?
>> Greetings,
>> Andreas
>> On 21.03.2016 14:47, Albin Blaschka wrote:
>>> Am 21.03.2016 um 14:20 schrieb Bernd Vogelgesang:
>>>> sounds maybe to easy, but why don't you just make a spatial query
>>>> on your coverage grid to select and save those elements which do
>>>> have points inside (Grid Layer Contains Points Layer e.g.) and then
>>>> use that new coverage layer to produce your Atlas?
>>>> Or do you search for a more clever approach?
>>>> Cheers
>>>> Bernd
>>> Hello Bernd, Joris & List!
>>> Ah, yes - that would be a possibility, which I did not think of -
>>> Thank you both!
>>> ...but in general I was on the quest for a "more clever" meaning
>>> here "dynamic" approach, I have to admit: So, the aim would be in
>>> future, just opening the project, printing the atlas without further
>>> intervention and getting an "up-to-date" atlas...
>>> But in the meanwhile, it should be ok with the "manual" approach.
>>> Thanks and greetings!
>>> Albin
>>>> Am 21.03.2016, 13:53 Uhr, schrieb Albin Blaschka
>>>> <albin.blaschka at standortsanalyse.net>:
>>>> Hello List!
>>>> I am starting to use the Atlas feature for the first time and had
>>>> the following problem:
>>>> I have a coverage-layer (a vector grid) and a point layer
>>>> (collection sites). At the moment, there are grid cells in which no
>>>> site (point) is located.
>>>> My problem is: I would like to filter those "empty"
>>>> atlas-elements/pages out. In other words, if the atlas-page
>>>> contains no element of the point layer, it should not get
>>>> printed/produced.
>>>> I tried myself and failed, I googled and failed...
>>>> Is this possible and if yes, how?
>>>> Thanks in advance,
>>>> Albin
>> Qgis-user mailing list
>> List info: http://lists.osgeo.org/mailman/listinfo/qgis-user
>> Unsubscribe: http://lists.osgeo.org/mailman/listinfo/qgis-user
| Dr.rer.nat. Albin Blaschka
| Etrichstrasse 26, A-5020 Salzburg
| * www.standortsanalyse.net *
| * www.researchgate.net/profile/Albin_Blaschka *
| - It's hard to live in the mountains, hard but not hopeless!
